It won't run well
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beachinblazer, Nov 19, 2002.
  1. beachinblazer
    beachinblazer Registered Member
    Apr 15, 2002
    20
    It won\'t run well
    I've got an 86 K5. Just 2 days ago it started surging if I gave it too much gas and it would die. It ran fine if you feathered the gas pedal but wouldn't go above 30. I replaced all the fuel filters again, checked the lines and it still won't run well. It'll last for about 2 miles before it'll die, then it takes about 10 minutes to get it back running and it'll die in about 2 minutes. Anyone have an idea of whats happening? The fuel pump was installed in may. I'm doubting thats the problem. Something more hidden. Thanks
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Re: It won\'t run well
    Sounds like a clogged catalytic converter, but can't be sure.
    John
  3. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I had a similar problem and it was the distributor cap. It wasn't on properly.
    You also might want to check the timing.
    Good luck! /forums/images/graemlins/smile.gif
  4. Grim-Reaper
    7,385
    Atlanta
    Choke is not opening. Bad element.
  5. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    My vote is for a stuck EGR valve.
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I'm willing to bet it's a stuck needle or float.......
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well I am not willing to bet here, but I have had this problem with a busted distributor, the springs on the weights broke and the weights would just open too soon.
    I wouldn't think it's the float needle stuck because actually it would flood the engine much faster and the only way you can drive it is WOT, I know because it happened to me and that's the way I got home to fix it. /forums/images/graemlins/thumb.gif
    So check your distributor, vaccum lines, and I also wouldn't rule out a clogged cat or EGR.
  8. Grim-Reaper
    7,385
    Atlanta
    Choke.
    Take the top of the air cleaner off and see if it's opening. After about 5 minute electric choke should be close to full open. If it's not open the engine slowly drounds in fuel. It will smell like gas out of the tail pipe.
