It wont start!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77k5bogger, Feb 4, 2003.
  1. 77k5bogger
    77k5bogger Registered Member
    Feb 3, 2003
    40
    Winneconne Wisconsin
    Alright my k5s acting up. It wont start. Just cranks over and over. I replaced the ignition modual new plugs, fuel filter, recently. Its getting gas and it also has spark. but it just wont fire up. I spray starting fluid in the carb and it sounds like it is gonna start but it doesnt. Im getting frustrated. The engine is a 77 350 with a quadrajet manual choke. If you guys have any ideas pleas help me. thanks, Derek /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The only issue left is either timing or wrong order of the plugs.
    I am assuming it was running before the change so timing chain is not an issue?
  3. 77k5bogger
    Feb 3, 2003
    40
    Its not the order of the plug wires I checked it like 10 times my friend checked it too. Yeah it was running before. When I checked the spark it looked kind of weak. Would it maybe be my coil?
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    change the coil if you can. I would check under the cap to ensure everything nothing is loose. I take it you did not remove the distributor. Make sure the coils red wire is making good contact with the power connector.
  5. 4DiggerDan
    4DiggerDan 1/2 ton status
    Feb 2, 2003
    103
    Montucky, USA
    Did you just have the distributor out for any reason? Could be 180 out..?? Spark doesn't do you much good on the exhaust stroke ya know /forums/images/graemlins/wink.gif
  6. 77k5bogger
    Feb 3, 2003
    40
    No I didnt take the distributor out. I m going to replace the coil tomorrow. I ll also make sure nothing is loose.
