It's a dog on the HWY.
Discussion in 'The Garage' started by big jimmy 91, Apr 11, 2004.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    It\'s a dog on the HWY.
    My truck suck's with the 307's /forums/images/graemlins/angryfire.gif ( 13 pinion , 40 ring)
    What is the lowest ratio offered , factory 10 bolt's
    BTW. 350 TBI. NP241. 700R soon to be 33x12.5x15's used for DD , mud , trail ,poss. a little rock crawling
    What ratio would you recomend keeping in mind that being a DD with alot of highway milage is a factor
    Thanks /forums/images/graemlins/ears.gif
    I also will be pulling a small camper in the future
  2. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    Re: It\'s a dog on the HWY.
    with a 700r4 go with 4.10s or 4.56 gears. biggest factory offered was probably 3.73, but some probably came with 4.10 if you ordered them.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if it was me id go with 4:56's /forums/images/graemlins/thumb.gif
  4. big jimmy 91
    Feb 21, 2004
    639
    would that kill fuel milage?
    seems a little steep for a DD /forums/images/graemlins/thinking.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would say 4.56 is just about right, and go all the way to 5.13 if you're planning on going with bigger tires.
    5.13 x .7 (OD ratio) = 3.59:1
    4.56 x .7 = 3.19
    Looks like a big number until you factor in the overdrive.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you might get a little less mpg but you have the 700r4 so you would be good on the highway and you said you do some towing and the 4:56's would work great for that. you wouldn't get that much less mpg maybe 1-3 mpg less if anything
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    ive got 4.56 on my truck with 33's. i think its perfect. accually helped mileage causs my truck was working too hard to turn the tires in OD with the stock 3.73's. my truck turns about 2500rpm at 70-75, but i usually run about 75-85 at 28-3000 rpms. so if you go 80+ on the freeway for long distances you might consider 4.10s.
  8. big jimmy 91
    Feb 21, 2004
    639
    Speed limit here in Ontario is 90 KPH. or 55 MPH /forums/images/graemlins/angryfire.gif
    But our roads are crap compared to the interstates south of the border
    We also have a lot of large animals to dodge /forums/images/graemlins/yikes.gif (moose etc.)
    So 3.73 and 33" wasn't a good combo?
    The RPO. codes say I have 3.08 ratio .
    Mabey I will just wait and find heavier diffs. to run a steeper ratio
    Thanks /forums/images/graemlins/thumb.gif
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I'm in the same boat as you= 33's 3.08/3.07 700r4, but I have a 305 and 65 mph in OD equals 18-1900 rpms tops /forums/images/graemlins/yikes.gif
    If I don't use OD I can make it work for now. If you have funds for gears go for it, if not keep it out of OD until 65 mph or so. At least you have a 350, my motor plans are on hold for a bit. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  10. grd2go
    grd2go Registered Member
    Mar 28, 2004
    55
    Anchorage Ak
    I have a 89 full size GMC Jimmy TBI350 700R4 and 241 t-case with 373 gears and 33/12.50/R15 It cruses down the highway but still does good offroad with the low first gear the tranny has. It also has a 2.5 in lift to make the tires clear all in all its a good DD but I only do light wheeling in it cross a few rivers play a little in the mud climb around on the smaller rocks nothing major I have another truck for treebashing & rock rubbing so I try to be nice to my DD. /forums/images/graemlins/k5.gif /forums/images/graemlins/crewcab.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif
