Its a long shot but...
Discussion in 'The Garage' started by k5freak44, Feb 5, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Im having trouble finding a 9in grade 5 bolt. Is it possible totake a 8in that i can find and cut it and weld in another inch of grade 5 bolt?
    If i did this would it have more strength then a grade 2 bolt?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    unless you are a good welder it will be weaker than grade 5 for certain. Whats this for? You should ALWAYS try and use the shortest fastener you can, its just stronger to use say 2 1" long bolts than 1 9" long one.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what you ned them for, what are you doing ?
  4. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    1in bolts wont reach!
    ive gotta go thru my floors thru some 3in body lift blocks, mounts, some bushings and the frame. If i coulda used 1inch this problem wouldent have exhisted!
    Thanks tho
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    grade 8 all thread? nut at both ends. Just a thought.
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You can't find the right size at a good hardware store? If it was me and couldn't find the bolt I would get a piece of all thread, cut it off at the right length, and just tach weld a nut at one end to keep it in place as the head.
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I dont know if this is the same thing Alan is talking about, but my dad bought a bunch of 12'+ lengths of threaded rod (probably not grade 8 though) and whenever we didn't have a bolt at home, he would cut off the rod, and use nuts at either ends.
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah thats what I call All Thread, different names for it I'm sure.
  9. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    McMaster.com has them. Type in bolt, then fill in the blanks after that. First select the length you want.
    -Chris
  10. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    thanks guys
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    LOL I just called it rod because I didn't know what it was. Thread all it in then.
    Thanks Alan.
  12. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    look at a farm store
    You might try Tractor Supply or a similar farm store,they usually have longer bolts there than most hardware stores carry--I used some long carriage head bolts grade 5,used on plows and disc harrows,only place I could find both grade 5 and that long--the carriage head was a plus too,doesnt make a big lump under the carpet...I saw long enough ones at home depot,but they were grade 2--I have used them before too,with no problems--ANYTHING was better than the pencil thin rotted bolts I took out!..:crazy:
  13. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Is there an echo in here?
  14. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
