ITS ALIVE! But I have a fuel leak, need part number for std flare filter
Discussion in 'The Garage' started by jjlaughner, May 19, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OK here's the deal. Rusty Bucket was BAD! Fuel leaks at the tank and most of the return line was rusted through. SO I went the normal route using std flared brake line and flared fittings. Not really thinking about it too hard I stuffed a Std Replacement 87 Blazer O-Ring style fuel filter inline and plumbed everything off that /forums/images/graemlins/doah.gif SO now I have a fuel line leak at the filter. Do any of the fuel filters use a 3/8 std flare line fitting? Maybe one for an older truck or are those all in carb fuel filters?
    (I think I used 3/8 fuel and 5/16 return /forums/images/graemlins/thinking.gif)
    ANyhow I had to jerry rig a ground line to the battery(the frame IS THAT RUSTY I couldn't get a good ground), then I cranked it over a couple times, before it started I ran inside to grab the camera. So I have quicktime video of it starting , running and the exhaust leak (right click save tarage as). With just a couple cranks (less than 6 seconds) it started right up like it was running yesterday! An its been sitting for over a year!
    Pics:
    /forums/images/graemlins/1zhelp.gifPart numbers anyone? /forums/images/graemlins/ears.gif
  2. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    Does this mean it will be at the Badlands Saturday?
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i think my s10 fuel filter used a standard flare fitting. ill go pull it off in a few minutes and let you know. /forums/images/graemlins/waytogo.gif
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif NOPE /forums/images/graemlins/deal.gif
    see this pic
    [​IMG] /forums/images/graemlins/whistling.gif
    -No tailights (or housing for the taillights to mount too, I bought LED trailer lights to install)
    -Leaky fuel line
    -jerry rigged ground wire (and the sender still doesn't work /forums/images/graemlins/confused.gif I thought it was a ground problem at first since the pump didn't kick on, after the high tech wiring job the pump kicked on but the sender says I have 15/8's of a tank (IE its WAY past full).
    -notice the battery is sitting on a 2x6 on the front tire /forums/images/graemlins/tongue.gif (also the radiator support is not even connected to the frame... there's a new radiator support in the bed that needs installed as soon as I find some bushing cups for the new poly bushings to mount to)
    -look inside the truck... there are no seats or belts
    and this winter there was a popping nosie coming from the drivers side axle ujoint... and i dont have a trialer to get it to or from (no tail lights too, or broken axle shaft from) /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
    Hopefully the next run I will have lift and tires, OH and seats /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/whistling.gif
    As soon as I get these 14bolt spindle nuts pulled off to remove the drums, the axle is ready to swap you this weekend. Did you get my PM about the carrier? /forums/images/graemlins/tongue.gif
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    SWEET /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    The fittings for that type of filter are "Saganaw" fittings.
    16ml X 1.5 thread.
    They have them with the Saginaw fitting on the filter end and a flared AN fitting on the other.
    Year One has them,13 bucks each.Part number DE39
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/thinking.gif The filter is not that big of a deal, if I can find one with regular flared fittings that cost $6-7 bucks I'll go that route. I had to buy those fittings for the front lines. I have as much in those two fittings as I did all the hard lines, flared fittings and the brake lines I replaced /forums/images/graemlins/tongue.gif
    Thanks for the info though /forums/images/graemlins/waytogo.gif
  8. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Just get two fittings that will turn your 3/8 flare to a 3/8 nipple fitting and get the filter off of a 90 jeep cherokee (#3641) it uses 2 3/8" nipples and a short chunk of 3/8 rubber line.
    thats how i was doing the wagon til i got all new stock lines off a 91 in the yard.
  9. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    I know.Those specialty fitting prices are NUTS!!!!
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its a oring style fitting, sorry /forums/images/graemlins/crazy.gif
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    What about aftermarket filters for race cars? Are they all rubber line barbed fittings also? /forums/images/graemlins/thinking.gif
    Maybe I just need to take a fitting and go try a bunch /forums/images/graemlins/smirk.gif
  12. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    racing ones I seen are AN fittings. When I was doing mine I tried every filter on the wall.
  13. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Well thats not making me any more hopefull /forums/images/graemlins/smirk.gif
  14. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Do you still have the original o-ring lines from the old fuel filter? If so you could just splice in those ends with a couple compresssion unions. It might look a little cheesy, but it won't leak and will be more solid that using rubber hose. /forums/images/graemlins/dunno.gif
  15. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    nope all the old stuff was rusted through. I snagged some front flex lines and bought the oring fittings for those ($16 each from car quest). The rear lines on the tank got the ends cut off and compression fittings put on there.
    There was nothing salvagable from the oringinal brake or fuel lines.
  16. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    bump back to the top
    Other than splicing in some rubber lines anyone else have a fuel filter idea?
    Man I'm going to hate life if I have to buy $30 worth of fittings for a $4 fuel filter /forums/images/graemlins/deal.gif /forums/images/graemlins/whistling.gif
  17. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    After all you have done to that truck, your now gonna worry about 30 bucks to fix it right ? /forums/images/graemlins/eek.gif
  18. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    $30 when you've been unemployeed for 16months is alot /forums/images/graemlins/deal.gif
  19. dyeager535
    26,979
    Re: ITS ALIVE! But I have a fuel leak, need part number for std flare filte
    I know almost nothing of the old old Cadillac fuel injection systems. I believe they were around in the late 70's, and that was before the saginaw fittings you are having trouble with.
    Since they were around before the saginaw fittings, perhaps asking for one of those filters (I kind of think those are going to be tough to find) will net you what you need? It's the only applciation I can think of that might hold some promise.
  20. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    the 15/8's tank of gas aint much to worry about if the tank is full that is lol. My gauge reads way over full when i top it up. run it a couple days, then it drops to about a half tank. If its at a half and i add $5 (well 10-15 now lol) itll go up to 3/4 of tank. Its just a little slow at droppin lol.
