Its all about the torque baby...
Discussion in 'The Garage' started by Topdown, Feb 24, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok... I am going to be rebuilding my 350 and want the most torque out of it I can get without building a stroker or a big block (cause I already know there is more torque to be had there) ... So, I figure Vortec heads, clean 350 bored .030, flat-top pistons... What intake? Cam? I am going to put TBI on it so no carb to worry about... Thoughts?
    Right now I am thinking Edelbrock Air-Gap dual-plane but thats because thats what I have in the garage... is there something better? I was also thinking of the Xtreme 4x4 cams..
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Well I would stroke your 350 or build a big block... /forums/images/graemlins/histerical.gif
    Sounds like you basically have it planned out already and I would say you have some pretty good choices there. I would use a regular performer intake but thats me. I would agree that the comp cams 4x4 line would be best. /forums/images/graemlins/thinking.gif
  3. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Ive heard of ppl putting RV cams in an engine to get more torque. You could try that
    Nick
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im going with comp 4x4 xtreme 12-238-2. 430 lbs tq at 2500 rpm /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  5. dyeager535
    26,980
    Air-gap won't fit the Vortec heads, if thats what you were intending. (thats also assuming it isn't a Vortec Air-Gap)
    For the cost of Vortecs with the special intake, you could get a set of better heads (World's, AFR's, Pro-toplines, etc) and use the Air-gap. Of course, I guess you could run a standard intake with a TBI adapter on the Vortecs, but that's ghetto if you ask me, when there are intakes already made for it, or another approach thats possible.
    Cam you'll want something in the 112* LSA area, and not real radical. TBI doesn't like too radical cams (low vacuum is a real issue), and the less extreme the cam (to a point) the more low end torque you will make. All will be an inhibitor at higher RPM's, but for a heavy truck, low end torque will make you happy unless you like to race it.
    A mild roller cam would be the best, but the cost is pretty prohibitive, unless you've already got a factory roller block.
