It's always something.....or........screwed again....
Discussion in 'The Garage' started by Desert Rat, May 22, 2004.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    It\'s always something.....or........screwed again....
    I damn near broke my arm patting myself on the back tonight after I got my Corp14ff bolted in. Had to chase down some u-bolts, but finally got everything hooked up. As I stand there admiring my handywork, and feeling mighty cocky, I decide to get a closer look underneath. Yep, everything looks perfect....but wait......what is this I see? *&^%$#@!!! /forums/images/graemlins/angryfire.gif the angle between the Gear Vendors OD unit and the Corp14 pinion is SEVERE!! Not to mention now the driveshaft will only be about 2 ft. long. CRAP! I'm thinking not even some angled shims and a double cardan is going to fix this one. That GV OD unit is a sweet unit but it adds about a foot onto the back of my NP205. Oh sure, everybody who has one loves theirs, but they are all tow rigs....... Well, back to the drawing board. Looks like I yank out the GV unit and live with the TH350 until I can save my pennies for a Bowtie Overdrive. Will the headaches ever end? /forums/images/graemlins/doah.gif
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Re: It\'s always something.....or........screwed again....
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gifNo /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  3. namkrow
    namkrow 1/2 ton status
    Apr 25, 2004
    166
    So Cal
    The short wheelbase will get you every time!
    You know...a manual trans is a lot shorter...lol
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    not in my experience. The adapter on the manual trans is so much longer that it makes up for the length and the differences between the auto and stick are very little if any. I just bolted my SM465 in place of a 700R4, and was amazed that not only was it the same length but the same shafts would work.
  5. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Probably the only silver lining in this is the fact that the GV unit will be easy to sell. Lots of folks swear by them and I think for a pickup or a Burb they are a nice unit. For a short wheelbase, apparently not.
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Sorry to hear about that....I have been there darn near every time I get under my truck /forums/images/graemlins/angryfire.gif It makes us stronger people in the end /forums/images/graemlins/grin.gif
  7. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    What you doing with the GV /forums/images/graemlins/thinking.gif I have a /forums/images/graemlins/truck.gif that it would be great in /forums/images/graemlins/thumb.gif
  8. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    whats this unit do ?
  9. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    wondering the samething too
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    it adds overdrive to your trans basically. Its a big gear unit that acts like the part of a tcase that lowers your gear ratio but instead it raises the ratio.
  11. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    It gives you an overdrive, but does much more. It also allows you to split gears. In other words, you can go from a 3 speed, to a 6 speed. For that reason, it is very popular for folks who tow stuff. When you get on a good grade, you have more options on gearing. Check it out here: http://www.gearvendors.com/ As soon as I get it out and all squared away, I will put it up for sale.
  12. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    aw man,thats to bad.i thought about running that setup as well.I remember along time ago i asked you about the thing.i also liked the idea of more gears.I hope everything works out for you,best regards.jake /forums/images/graemlins/thumb.gif
  13. namkrow
    Apr 25, 2004
    166
    So Cal
    I just went from a TH400/NP205 to a SM465/NP205 and the shaft needed to be lengthened by a good 5" (also had to relocate the trans crossmember forward about 4 or 5")
    I guess there's different ones, or the 700 is really loonnnggg (never seen one in person)
    -T
  14. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Yeah, I remember the threads. I threw out a bit of a test to see if there was any interest on the GV unit when I had planned on getting a Bowtie Overdriver 700r4. I think if you have a stock Blazer, which mine was when I bought it, then you are fine. Or maybe a very mild lift. But with the 6 inches I put on w/ the 35's, the angle is just too much. I don't think it would be an issue with a pickup and a lift as you have a lot longer wheelbase. I really liked the ability to split the gears going through the Sierras on the highway hauling my gear, but alas, not to be. The money pot has run out for this year so looks like I will be living with the TH350 for this season, then doing the Bowtie Overdrive next year after all.
