its been a bad day
Discussion in 'The Garage' started by shupach, Aug 25, 2002.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    so after spending a good amount of the morning cleaning up my garage, i decided to continue building the engine. My friend and i put in pistons 1,2 and 3 after i notice that even though i've torqued down the rods, they are on the journals quite loosely, wigglin back and forth. I also notice that the pistons arent too snug either. So my friend comes over, he used to race and build race engines, and takes a gander at my engine. We find out that the crank has been turned, therefore makin the journals smaller, and the cylinders have been bored, so now i have like a 415 instead of a 400. While the new displacement excites me, i realized i will somehow hafta coerce summit into returning my pistons for a new set that are bored 30 over, i will also need new rings and new bearing caps for the rods. its been an interesting day.
    phill
  2. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    /forums/images/icons/confused.gif /forums/images/icons/confused.gif That would confuse me because I wouldn't know wheter to be /forums/images/icons/laugh.gif or /forums/images/icons/mad.gif
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    me too.
  4. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    Excitement and a little worry at the same time. I wouldn't know which one to except.
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    The rods are supposed to move back and forth a little. Now not slapping all over the place mind you. If they didn't move, than you'd have more problems. Measure the crank and find out what size bearings to use.
  6. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    If the crank was turned by a decent shop then it will be stamped with was it was turned to (10/10, 20/20, etc). This should help you find the right sized bearings.
  7. shupach
    Dec 28, 2000
    648
    Dallas, TX
    ya we checked stuff out with the micrometer, the crank is .268, we checked the old bearings with the new ones and they were thicker. ill give summit a call tomorrow. i cant wait to pop the hood of the truck and be like ya its a 406...small block.
    phill
  8. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I could've been worse.........When I lived in Linden,Wa. I had the machinist do up my long block but not assemble it. I got it home and found out I had the right block but wrong rotating assemble........took a little bit of time to figure out that they gave SBC400 crank with .030 over 350 kit. That was all kool though I just had the machinist do up my block for a 383 stroker!
    Bill
