its been ask a million times but
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by orangecrush 72, Feb 4, 2004.
  1. orangecrush 72
    orangecrush 72 Registered Member
    Aug 23, 2001
    19
    will 33's fit on a stock 90 blazer? it has 32's on it now. there is no lift on it now but it does sit up pretty high stock. any help would be appreciated.
    /forums/images/graemlins/usaflag.gif
  2. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Uh - I imagine if there is anything over an inch of space between the wheel and fender - Yes they will fit?
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    If it has 32s and it's a 90 then 33's should fit no problem, the main issue is the width. Are they 12.50s? Anyway, 1" won't make that big of a difference...
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Yup, it's been asked a million times and people have given their opinions a millions times and the consensus for the majority has been yes.......... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. dyeager535
    26,979
    There is no correct answer. Some trucks yes, some trucks no.
    Stock ralley wheels, no lift, 33x10.5R15's clear on my truck no matter what I do, I think that is most everyones experience with stock wheels, stock suspension, and this tire size.
    33x12.5R15's seem much more likely to rub when turning, flexing, etc., from others experiences.
    Width is the important factor here, along with the varations among each truck.
  6. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    I agree i had 33 10.50 stock never hit at all but my buddy had 33 12.50 and rubber a bunch
  7. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    I have 33x12.50x15 BFG Muds on my '87 and only get a little rubbing when flexing.
  8. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    no lift and 33s? i run that setup on 15x10s
    i dont rub..
  9. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
  10. Hustler
    Hustler 1/2 ton status
    May 14, 2001
    326
    St. Peters, MO
    I have a set of 33 x 12.50 Pro comp Xterrain on 15 x 10 rock crawlers and I don't rub on the street. I have only rubbed once while off road riding. I don't try to flex my Jimmy much off road because I know they will rub then. I say you can do it for a DD or mild off road trail riding.
  11. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i had 33x12.5x16.5's on 16.5x8.25 and they would barely rub when turning and flexing.
  12. dyeager535
    26,979
    If you ask me, rubbing is the embodiement of "not fitting". /forums/images/graemlins/smile.gif
  13. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Poser pic, 33's on 1990, no lift /forums/images/graemlins/whistling.gif
  14. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Oh yeah, and no rub /forums/images/graemlins/woot.gif
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It depends on wheel size, backspacing, the condition of your body mounts....etc. Like you said, some trucks fit, some hit. Mild rubbage doesn't necessarily mean that the tires don't fit, either.
  16. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    [​IMG] /forums/images/graemlins/thumb.gif /forums/images/graemlins/waytogo.gif
  17. dyeager535
    26,979
    Stock tires/wheels/suspension don't rub. Therefore, any tire that rubs without making changes to the vehicle, doesn't fit. /forums/images/graemlins/smile.gif
    I've never seen an all stock K5 with such poor springs that stock tires rubbed.
    Hardcore's truck has the stock AL wheels, IIRC, those are 1" narrower than the steel ones, and the tire brand itself could also impact the "rubbing", as well as spring condition/how may leafs, and all the other variables there are.
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you did, would you say that those don't fit, either?
  19. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    how come mine rub. On the street only the right rubs when turning. Offroad all hell breaks loose. They are just 33's on a 90 with no lift, Why??????
  20. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    It depends.
    I have a 4" lift and they rub.
    But I don't have a swaybar.
