Its cold and I need some blower motor help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Mar 2, 2002.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    So I'm driving down the street and the blower just kicks off. It was on high and it just died...but here is the weird part. The lower 3 settings still work fine. Its just when I put the switch on high that the motor completely dies. If a fuse blew, don't you think that all the settings would be dead? What controls just the high setting besides the switch. BTW the switch was replaced with a new one from LMC last summer. Any ideas? Thanks
    '73 K5
    Chevy good...Ford bad
  2. calvin
    calvin 1/2 ton status
    Oct 23, 2000
    152
    Brownstown, Michigan
    It's your rheostat on the outside of your heater box. Change that and all will be good
    <a target="_blank" href=http://irocz.cz28.com>http://irocz.cz28.com</a>
    79' Chevy Custom Deluxe shortbed K10, 396 ,pics on site
  3. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    its the relay, the rheostat does nothing on MAX..
    before replacing it, check the ground first.. the relay has its own ground and that is a real common problem
    keep us posted
    mike
  4. '73 K5
    1,763
    Kansas
    Thanks for the help guys. This afternoon I was able to get the blower back to normal...hopefully it will stay fixed. I took the resistor out and sprayed it down with some contact cleaner...jiggled some wires and pushed down on all of the connectors. Thats it and it fixed it. Probably just a bad contact somewhere, but if it happens again I'm going to replace the relay first.
  5. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    i have same problem! where is the relay?
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Look for a square metal can (about 2x2x1") on the side of the A/C box in the engine compartment. It's got a 12 or 14 gage orange wire going to it, should be easy to spot. The relay cover comes off, and if the contacts aren't burned and pitted, you can take a business card and clean the plated contacts, instead of replacing it. HTH
  7. Bigmeats
    Jul 29, 2000
    523
    Manhattan IL
    Thanks for the help. Ended up not being that at all. The in line fuse connections needed a good cleaning with a wire brush.
    Thanks again
  8. johnnyK5
    johnnyK5 Registered Member
    Oct 5, 2001
    95
    Washington, PA
    Sounds like your going to need a new motor ($18.95@Autozone). That was one of the symptoms mine had about 6 months ago. Mine wouldn't work on high and then started making this weird whining noise kinda like when your water boils in your ratiator after a thermastat stick. It finally puked last week. Very easy install.
