its getting cold, and i need a little help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by milspecjimmy, Oct 17, 2002.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    my heater will work fine on low, med, and high, but when i put it on max, it goes back to low speed! any ideas? i replaced the switch and it stil does this.
    thanks
    ~~~jeff
    /forums/images/graemlins/k5.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you changed the switch and still does the same then your wire that feeds the direct connection on the blower could be bad.
    The thing is the switch goes through a series of resistors on one line and then in the max position switches to another line that gives full voltage to the blower.
  3. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    what color is this wire? and where does it go?
  4. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    The relay at the heater blower might be bad. Check this, I have had that go bad on several of my vehicles.
    Just a guess
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I will check it out tonight and let you know tomorrow
  6. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    kool, thanks a lot
    ~~~jeff
