Its Here!!!
Discussion in '1992-Present Chevy & GMC models' started by beater_k20, Nov 7, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    came home today to a nice big box sitting in the garage... return address... Sky Manufacturing...
    brackets are pretty beefy, made of 3/16" and 1/4" lazer cut steel. the front crossmember is CNC bent. the only thing, mine doesnt have the "Sky's Offroad Design" logo cut into it like most others do. not 100% sure that that's standard with this kit, although Sky did tell me at one point that it was optional. i believe it was 15.00 extra if it wasnt on there, but i could be wrong. the shackles are 3/8" CNC bent pieces, 4.25" center to center. the kit appears to be pretty much bolt on, with slots in the front crossmember that bolt to the area where the stock tow hooks go for adjustability, and 4 bolt holes on the rear hanger. i plan on bolting mine together, loading the rolling chassis onto a trailer, and taking it to work and buzzing it together with one of the industrial welders.
    checking the measurements the hangers are just a bit off of the 32.5" spring spacing,. the outside tabs are spaced about right, but the inner tabs are a little on the narrow side, nothing a couple washers wont fix, and should make the kit usable in Chevy Ford and Dodge axles.
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and the long awaited pics...
    another thing to keep in mind, mine is the first customer unit short of the prototype, out there. anything i run into that could make the kit harder or easier to install will be relayed to Sky.
    BTW, pricing is $350 TYD.
  3. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    mmm...beef, i cant wait till i order mine :bow::bow:
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    So the only bolts that hold the front crossmember to the frame is the 4 bolts that go where the tow hooks were?
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yes, but it is recomended that the brackets be welded in. or, you could easily add some braces to the side of the frame if you felt that was necessary. i'll probably end up going that route.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    those shackle brackets are really trick pieces. DEFINETALLY the best setup I've ever seen a company make. Front brackets aren't stunning, but could be fixed up nice. debating whether I'd be better just getting their shackle mounts and making my own front mount.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    just out of curiousity, what are you thoughts on making the crossmember better? i've got a few ideas...
    a couple of triangular gussets between the top of the crossmember and the inside of the frame.
    box the bottom of the crossmember.
    and a couple of brackets that fit inside the front body mount to the top of the crossmember on the outside of the frame.
    got anything else? :confused:
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    just a gusset from the backside of the member down the framerail a little bit. keep it from folding backward if you hit something head on. Other than that you said all the things I'd think of.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    maybe not even fully box the lower part of it, just add a couple pieces across the bottom of it to strengthen it up a bit.
  10. divorced
    Jul 20, 2004
    5,115
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    they're only 2.75" wide though...
    keep in mind guys, this is the first kit out. they might be changing.
  12. divorced
    Jul 20, 2004
    5,115
    The inner width is 3". How wide are the front springs (outside of bushings)?
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    3.5" i do believe. they're wider than a set of rear springs, which are 3"
  14. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Aftermarket leaf springs (for the front) are 2.5" wide with bushings that have a 1/2" shoulder on each side to make them 3.5". rear springs are 2.5" also but with bushings that use 1/4" shoulders, use the bushings for a rear spring eye in the front and problem solved!:D
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    er, uh, they're too wide, not too narrow. the spring is smaller than the perch.
  16. 79k20350
    Nov 22, 2004
    7,757
    Ct
    whats too wide, where? not sure what ya mean
  17. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the inside to inside spacing on the perch, add a couple washers, and let Sky know about it so it can be fixed in future kits, no big deal.
  18. 79k20350
    Nov 22, 2004
    7,757
    Ct
    OOO, i was referring to divorced. sorry i must of replied to the wrong post:doah: I was just reffering to the fact that there are bushings out there that can be swapped around to make a 3" or 3.5" width from 2.5" wide springs so he could make the other mounts work
  19. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    any pics of it installed???
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    been too busy with other stuff, and havent been able to line up a welder yet. need to order some spring plates and ubolts too.
