its moved!
Discussion in 'The Garage' started by 84gmcjimmy, Oct 22, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Here are some pics of what I accomplished today:
    Just one thing... Its hard to move a blazer when there is only yourself doing it /forums/images/graemlins/yikes.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    That's a hell of a snorkle you have there Steve /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  3. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    So when are you going to home depot for plywood to cover the walls,and put in the woodstove??? /forums/images/graemlins/laugh.gif /forums/images/graemlins/thinking.gif
  4. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    There's an idea for ya.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    If I had the money for plywood I would do it. But im tight on money right now. 30 bucks a sheet, and I'll need quite a few /forums/images/graemlins/dunno.gif
  6. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Blue tarps or sheet plastic works too,and is a lot cheaper--but theywont like the woodstove if its too close!.Just being out of the wind is half the battle won,it would be much better closed in,if only with plastic--you'll get a little solar heat if its sunny and fairly airtight.Anythings better than working outside in the winter!. /forums/images/graemlins/crazy.gif
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    2 years ago when my dad and I replaced the clutch in the jimmy, we wrapped the carport with plastic poly. Then we used a tiger torch (big torch that runs off propane tank) to heat it. it worked pretty good. The only problem is heat rises, and we were on the ground. so it still was cold /forums/images/graemlins/crazy.gif
  8. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I hear ya--no matter how warm the air is,that slab is damm cold!--I still wish I had the dough when I built my garage to put radiant heat tubing in the concrete floor for radiant heat--it heats the concrete with hot water in the tubing,which in turn heats the air--nice warm floors are perfect for lying under you rig--my friend did it when he built his shop--he used a hot water heater(electric-==expensive /forums/images/graemlins/yikes.gif)and a woodstove to heat the water--its nice to lay on a nice warm floor while its snowing outside,a heck of a lot better than lying in the snow,like I've had to do many times--I put a clutch in my blazer in january in four inches of slush--I dont care to do that again--EVER!. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/screwy.gif
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    four inches of slush? that sounds like hell /forums/images/graemlins/yikes.gif
  10. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I just tried this tonight for the first time. get one of thos egg-crate foam mattress things to lay on. Fold it in half then move it wherever you need it. Takes the chill off the floor. soaks up fluids well, and doesn't cost much /forums/images/graemlins/waytogo.gif
  11. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Go and get yourself a carpet remnant. They work good for lying on.
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have a lot of left over carpet in the shop from when we recarpetted 2 years ago. I'll eaither use that or the egg carton foam sheets. thanks for the suggestions! /forums/images/graemlins/peace.gif
  13. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    The carpet will be easier to move around on than the eggcrate stuff
  14. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I use a sheet of that foam insulation board with the foil backing on it--its fairly cheap at home depot or similar stores,the pink stuff without the foil works good too,but it isnt as rugged as the foil faced stuff.This keeps you off the cold floor,and wont soak up fluids like a sponge like the egg crate matress pads do--I've used the egg crate foam and carpet underlayment foam for soaking up spills in the shop--once I lost 3 qts of dextron from my van during a motor swap-I stupidly stuffed a rag in the dipstick hole,and at acted like a wick--drained three quuarts all over the floor overnight-,had to swim in it until I thought of using the egg crate stuff to soak it up--then I put it in the woodstove--had plenty of heat for the next half hour--but the smell and smoke was horrible--more than one neighbor was giving me dirty looks that day! /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    LOL okay I might try that foil stuff to then. Carpet is first on the list, beause I already might have some. Otherwise I will check at the stores for foil stuff, or that egg crate foam. /forums/images/graemlins/peace.gif
