it's time to laugh at me (axle question)
Discussion in 'The Garage' started by BigOrange90Jimmy, Nov 28, 2002.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    it\'s time to laugh at me (axle question)
    Aight, I'm building a Toyota. I'm putting in a V8 and fullsize axles. I imagine I won't run a tire bigger than a 38. I'll have the ol' 14b in the back, but I'm stumped on the front. Should I go with an 8 lug 10b, which I have, or a D60? Keep in mind this is a VERY light rig compared to a K5, and I will have a removeable fiberglass front clip and a flatbed. If there's any questions, just ask.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Re: it\'s time to laugh at me (axle question)
    8 lug D44. the only catch would be the added weight of the V8
    if you were keeping the 4-banger, a built 8-lug would be bomb-proof. a 14BFF rear is way overkill, but nice to have. Drop a detroit in the rear and you won't even have to carry spare parts for the rear axle. the weak link will be way upstream.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If the 10 bolt is complete and ready to bolt in then run with it. Keep your eyes open for a 60, when you find one get it for the ultimate in beef. </font color>
  4. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    A buddy of mine is running dual t-cases on a flat bed 88 yota SFA running 37's. He swaped out his burfeild for a HP 44. Hes had it on there a year now and i havent heard much complaints. He still goes through his fair share of u-joint in it tho. Hes naver lost a shaft either but he still has the 4 cylinder.
    Personal opinion is that you could get away with it as long as you take it easy. Just like anything else.
  5. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    I would keep the 4 banger, but there's one problem. The truck doesn't have one in it and I'm not going to buy one just to get tired of it later on. This truck had a V8 at some point in its life because the motor mounts are in it and the guy claims it had one. I'm using the 14b rear because I already have it and I figure I'm going to give it hell at some point, and I want that added security. The 465/205 combo will be in there also, so I'm not worried about the drivetrain from the engine to the rear axle. It's just the front that has me stumped. The truck came with the stock axles, and a person that has a Toyota already knows that the front axle I have is the strongest they ever put in them in stock form. This is the one that has the full tube length gussets. I'm guessing I can sell them as a set and partially fund a D60 if I decide to go with one. The only reason I'm running fullsize axles is for the stability and strength.
