I've been thinking about hacking 2" off my 14bff..
Discussion in 'The Garage' started by JK5, Jun 16, 2004.
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I\'ve been thinking about hacking 2\" off my 14bff..
    I'm sure most you have seen the 14bff on POR...
    that has 2" hacked off...
    I've been thinking about doing the same thing...
    but machining a plate that has some tapped holes..
    so I can attach a cover with more than 11 bolts..
    I'm also going to strengthen the top of the housing...
    What do you guys think???
    Do you think I'll weaken the housing to much to run in a k5??
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Re: I\'ve been thinking about hacking 2\" off my 14bff..
    IMHO, should be fine. Just use a good 1/4" (or thicker) plate type covers, and good grade 8 bolts. That thing is bomb proof, I breag big rocks with mine all the time /forums/images/graemlins/eek.gif
  3. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    It could hold up well if you know how to weld cast but none the less it is weaker. The good thing is that 14FF's are a dime a dozen most of the time!
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Seems like there would be an issue with sealing the lower part of the cover. /forums/images/graemlins/dunno.gif
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Thanks for the comments Fred and Justin.. /forums/images/graemlins/peace.gif
    I'm not going to weld a 1/4" plate to it..
    I'm going to start with 1" plate...and cut the housing more
    and mill a pocket to clear the gears...
    Then...with the added thickness...
    I can add more tapped holes... /forums/images/graemlins/thinking.gif
