I'VE GONE NUCKING FUTS!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OFFRDK5, Jan 16, 2001.
  1. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I\'VE GONE NUCKING FUTS!!!
    Ok...I think I have lost it here. My K5..loose steering..hard running..swerves at random...brakes funny....
    I went and played in some snow...I am stock BTW...I get out of the snow and start driving home waiting to hear something fail :) instead my steering has tightened up, doesn't swerve, steering wheel has straightened, doesn't brake funny and it runs like a bat out of heel. WHAT HAPPENED?!!? Did I leave my mind at the trail!?!?!?!
    SK-15
    J**P...it's whats for dinner!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    Roads? Where we're going, we don't need any roads!
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Re: I\'VE GONE NUCKING FUTS!!!
    OK First question..How much did you have to drink? Second question How much did you have to smoke. After the first and second questions are answered we can give you a better idea of what is happing....
    LOL LOL LOL
    Become one with nature............Then marinate it....
  3. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    It just needed some of that 'wheelin mojo vibe to make it feel better.
    "I'm not stuck...I'm just exploring the depth and texture of this mudhole for a while"
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I think all that banging around in the snow knocked a loose part back into place. You know the drill, u-bolts, perches, steering, etc.
    June 2001 - The Texas Sawz All masacre begins. Be afraid rust, be very afraid. [​IMG]
  5. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Could it be all that water(snow) washed the grease out of your balljoints and steering rod's making it tight because of lack of lubeerication(sp)? Maybe you should get the old grease-press and grease the joints back upp, just incase. Or you will have bigger problems later on.
    Also "hot-roding" the engine maybe cleaned out some old gunk, making it breath bether.. [​IMG]
    <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
  6. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    gokartergo:
    1) Sunny D
    2) None
    EdaTREE:
    Yea...I think it proves our K5 have feelings...it was happy then
    Blazer_Boy:
    Yea...thats an idea...now I have to find out which one it was!!!!
    Espen88k5:
    Don't think so...but I will check...and how many places are there really to grease up? Hot-Roding...hrm...I think the Stanadyne Fuel Treatment might have done it too.
    Also wondering about since I have manual hubs now? If one wasn't fully disengaged what would be happening?
    SK-15
  7. Grim-Reaper
    7,385
    Atlanta
    Yeah a manual hub still locked in can and will cause many problems that you had. So will a dragging caliper.
    As for grease....well it is recomended that if you submerge the hub that it be inspected for water contamination. Always grease you tie rods, ball joint, Slip shaft drive shafts and u,joints after water play. This will purge any water and crud out and make them last longer.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  8. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    OK, I think that you stole that line from Blazer454.
    that said I would check the bolts that hold all of your front suspension, then do what I ended up doing to correct this problem- replace the front bearings inner and outer.
    Dan
    <font color=red>get involved with land issues or lose the land</font color=red>
