Ive got a 73 k5 and have lots of play in the steering any
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kwcdawgfan, Feb 11, 2001.
  1. kwcdawgfan
    kwcdawgfan Registered Member
    Jan 13, 2001
    91
    Georgia
    ideas on what is causing this... My tie rods were worn out so I replaced all of them hoping it would solve the problem but no luck... If ive got my had at 12 clock on the wheel the tires dont start turning till I am between 1-2 or 11-10... Ive got power steering and of course 4x4... Also checked the bolts on the power steering and they were tight... Any suggestions??
  2. dewey
    dewey Registered Member
    Dec 17, 2000
    59
    MA
    let me start off by sayin' "i don't know" Here are some ideas..fluid full? Time for a new steering stabilizer? ps pump slipping some?
    D.
  3. kwcdawgfan
    Jan 13, 2001
    91
    Georgia
    I replaced the steering stablizer when I did the tie rods and the fluid is fine... Have a feeling its going to need a new steering pump
  4. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    It is most lickly slop/warn gearbox. A 73 would have some wear over the years you can adjust them to make them better or think about replacing it.
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
  5. dyeager535
    26,982
    191
    Check the "rag joints" in the steering column to gear box for wear. If thats not the case, check the "drag link" (adjustable piece that hangs off the pitman arm) and se if thats worn. My dads has play, mostly turning the wheel to the right, and its the drag link joints are worn out.
    Dorian
  6. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    KWC, On my '72 the suspension bracket on the drivers side was loose and allowing a ton of play. Funny how that all works. With your engine off, but the key in the on position (unlocking your steering lock) have someone work the steering wheel back and forth and watch the front left bracket for movement relative to the chassis. If you see this, e-mail me and I'll let you know how I resolved it.
    madbishop@msn.com
    You can't beat going Topless!
  7. 73Jimmy
    73Jimmy Registered Member
    Mar 7, 2000
    31
    Idaho
    Did you check the frame at the steering box for cracks?
    I kept reading about the cracking problem on this board and
    decided to look for it on my rig because I had a lot of play
    in my steering. (This was after a new draglink and wheel alignment.)
    Only the top strap of the frame was left! The bottom and
    the side were cracked through!
    Good luck,
    73Jimmy
  8. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    My 87 was doing the same thing. It was the drag link ends. Replaced them, truck now drives like new. Very easy job.
  9. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I also had the same problem. I replaced the gear box
    and what a difference it made the truck is like new I found one at a auto parts
    store and paid about 200.00. Hope this helps
    Bo
  10. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    hey man! i had the same problem with my 85
    fisrt i tightend up the u joints, that helped, then i got DUAL steering stablizers from roughcountry [90$] and that helped a TREMENDOUS ammount. still has a little bit of play, but i can deal. then i have heard the ORD steering box brace helps a lot too.
    <font color=red> Confederate's w/ K5's! </font color=red>
    <A target="_blank" HREF=http://www.geocities.com/confederatek5/>http://www.geocities.com/confederatek5/</A>
    K5: Because size DOES matter
