i've got a newbie question
Discussion in 'The Garage' started by BIG*RED, Feb 22, 2006.
  1. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    I'm wanting to get 7 inches of lift out of the front of my k5.
    right now i have a 4 inch spring.
    and i want to keep the stock length springs in it. I wanted to try and stay away from a 6 inch spring, with the ord zero rate.
    so i was thinking 4 inch spring, 1 inch zero rate, and ???
    whats the best way of getting another two inches? or should i just get the 6 inch spring?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    BEST way is 6" and zero rate. Possible? 4", add a leaf, and zero rate. No garauntee of compatibility of the add a leaf and lift springs and I'm sure if you call the spring maker they will tell you to get new springs.
  3. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    worst case custom 7" springs . :D why no 6" and zero ?
  4. mello_yello
    mello_yello 1/2 ton status
    Jan 16, 2006
    167
    Orange, CA
    what size tires do youj plan to run ?
  5. BIG*RED
    Mar 14, 2003
    1,094
    Well it is my understanding, the higher the lift of the spring, the stiffer the spring and the ride..
    Not sure how much stiffer the 6 inch spring would be vs. the 4 inch spring..maybe not even noticable?.
  6. BIG*RED
    Mar 14, 2003
    1,094
    I want to run a 38 or 39.5...for more ground clearence. and at this point in time, the body on my k5 is in really good shape, and i just can't bring myself to cut it up......yet.
    Plus i don't really want to use a body lift..
    i'm running 35's with a 4 inch lift, and think that i should be able to run 38 or 39.5 with 7 inches up front and 7or 8 in the rear....depending on sag..
  7. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    You will most likely have to hack to run wide 38's or 39's with only 7" of lift. It all depends on how wide you go i guess.
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i have the 6in bds with zero rate up front, and 2.5 shakle flip in the back with 4 in springs and 0 rate
    i like the ride, handles better than my mom's stock blazer, even without the anti sway bar
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Get a soft spring, like a BDS or TC EZ Ride.
  10. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    I got 6" TC EZ rides up front now and they ride and flex much much much better than my procomp 4" springs ever did. To add to that, I wheel with a guy that has 6" procomps and he complains about the ride, both of up are not running the sway bar at all.
