I've got the bender blues
Discussion in 'The Garage' started by Bubba Ray Boudreaux, Oct 13, 2002.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I\'ve got the bender blues
    I've NOW gone through two sets of mounting bolts with my bender and I've only got about a 2 degree bend on the tube... This sucks. I guess it's time to get serious with the welder and Grade 8 bolts next go around........
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Re: I\'ve got the bender blues
    So your bending tube too big for the bender?
    Can you heat it up alittle as you bend it? /forums/images/graemlins/k5.gif
  3. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Na, just 1.25" .120 wall DOM. I think the problem is the mounting base isn't stable enough. This is a picture of my setup.
    I think the major problem is I don't have the square tube welded to the table, and that is enabling the whole unit to move as pressure is applied to the bender, so the only solid part of the base is the 3/16th" of the table. So I think if I don't find a better idea, I'll weld the tube to the table, so there will be two points of pressure on the bolt, which, hopefully will be Grade 8 or at least 5 with the new ones. I went today to get new bolts and all I could find was Grade 3 (same as what came with the bender). Last time, they had Grade 8, but not today.
  4. TONYP
    Aug 13, 2002
    2,116
    so cal
    I've found bolts at Ace and Lowes, Not sure what part of cal your in, If you need a plate or someting made up let me know, I have full access to a machine shop.
