Ive got to revive my 700R4
Discussion in 'The Garage' started by BigBurban350, Sep 21, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I think the 2-3 shift servo seals are bad because I lost 3rd gear. Everytime it shifted into 3rd it would slip bad. I rebuilt it once with new clutches and put a shift kit thinking it would help the 2-3 shift, nope same problem and I once again lost 3rd gear.
    I have access to jet washers to clean up everything in the housing and valve body. My only concern is where do I find new servo seals for the 2-3 shift servo? Would it be any better to find a new shift servo?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    TV cable adjustment, pull it a little tighter and test drive again, i have had this happen on several 700r4 on 2-3 shift, treadjusting cable took care of the problem everytime, sometimes it takes a few adjustments(little more tighter cable adjustment every time)
    good luck
  3. BigBurban350
    Jun 9, 2002
    711
    Michigan
