I've made the appointment to get a 14FF installed :) a few q's
Discussion in 'The Garage' started by BranndonC, Feb 18, 2003.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I\'ve made the appointment to get a 14FF installed :) a few q\'s
    Ok, i drop off my truck at www.GMTruckcenter.com (well the actual place) on march 5th to get some work done:
    14 bolt FF with 5.13's - i need suggestions for lockers, i was thinking gov-lock or something that doesn't effect my street mannors like i've heard the detriot does. again people swear to me that the Detriot isn't bad, but i have no experience with them.
    37 inch tires
    take a leaf out (i'm clueless here but someone said if i take some springs out it will lower the stance a little bit and soften the ride)
    Rims.... now i need help here.... i wanted to get 15 inch rims and grind the callipers, but Zakk has tried to talk people out of it before and others said that the breaks are so big anyway that grinding doesn't matter and nothing bas has happend to them.... So please give me input here
    At the moment the front is staying 10 bolt 3.73 and no 4wd for me till i get another axle... d60 if i can find one when i get the $$ /forums/images/graemlins/k5.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: I\'ve made the appointment to get a 14FF installed :) a few q\'s
    just go with the detroit they are not as bad as people make them out to be /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Detroit all the way. No other valid option.
    I like running 15's on my d60/14bolt. The brakes are plenty big enough so no worries. I had the 15s on my 3/4 ton front also and no worries, just buy a couple extra 4" discs for your angle gringer.
    Out of curioisty, how much is this all gonna set ya back?
    -- Mike
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im running 15's and have no problems after grinding the calipers.
  5. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    agreed, detroit, proven strength, I assume you got an auto tranny.... I can barely tell mine is back there, itll usually only chirp when i want it to, sometimes does it on its own.... If you had a manual then you would notice it a little more... but the Benefits FAR FAR outweigh the "bad street manners" that really arent that bad.
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i got a quote for $1250 from <font color="orange">doctor4x4</font color> (he works at gmtruckcenter) and is on CK5 That is basically a new axle, they start with an empty shell and install everything new.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I can notice the detroit, but only a bit.
    As for the grinding, I've preached my belief on them from any mountain top i can reach. 16.5's are not that bad, and hummer beadlocks (if you decide to go that route) are the only DOT approved plate style beadlock that i know of. There is not a 15" DOT legal beadlock I know of, and the safety bead doesn't hold all the time, Ask FRIZZLEFRY about that one...
  8. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Get the Detroit. I heard all the supposed bad stuff prior to installing the 14B with a Detroit in it. All I have to say it is that on the street it is no big deal, off-road, they are awsome.
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have to aguree with Zakk on the grinding of the calipers. I have seen how much some people have taken off and it is way too much! Brakes are something where "good enough" isn't! I did alot of research before I went with 15" rims. I ended up with some Eaton's with 3.5" of backspacing. I could bolt the rim onto the axle before I ground anything away...after I ground off the casting flash and smoothed out the caliper the wheels fit. Any more than that is IMO unaccepable!
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    on the rims why not get 16in rims? no grinding and they have the safety bead so you can air down?
  11. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Brandon,
    The beauty of the 14BFF is that the Detropit is CHEAP! It's one of the best things about the swap....to deny yourself the locker is silliness. You will notice a slight waviness on the highway when you get in-and-out of the throttle....it's the kind of thing that is subtle and won't cause safety issues but it's a difference over an open diff.
    16.5" is where the tire selection is....The hummer wheels/beadlock are a nice cost effective way to get set up for offroad and NOT grind calipers. Of course when you ask about 15" vs. 16.5" here you are NEVER going to get agreement from everyone!!! /forums/images/graemlins/grin.gif
    For a more conventional (and lighter) wheel setup you can do the TireLocs on 16.5" wheels which is what I did....there are pics in my .sig if you haven't seen them already.
  12. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Beadlock wheels are not illegal. DOT regulations state that in order for a wheel to be legal for use on public roads it has to have; 1) a manufacturer's name on the wheel, 2) date of manufacturer and 3) a load range specified. Since pretty much all beadlock wheels start as normal wheels that already meet these requirements, they retain they're legallity even after being made into beadlocks. The companys recomend that you not use beadlocks on the road to cover they're own asses, but nowhere do they say they are illegal. /forums/images/graemlins/thumb.gif
  13. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    not in my state, it says in the inspection manual, and a friend of mine had to go to great lengths to get out of a ticket for having simulated ones on his jeep. had to physicaly bring the wheel with no tire on it into the court, with no bolts in it and let the judge and the cop look at it, then he had to show them the advertisement showing it as a simulated one. it was only a 90 dollar ticket, but ins points are deadly.
  14. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I have heard of cops impounding cars with beadlocks ans slicks in fremont, so it might be OK in your state, but i KNOW its illegal in Callie.
  15. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    hmmmmmm. zakk your lying. because if bead locks are illegal in cali than im in big trouble. so im just going to say your lying and play the denial game. /forums/images/graemlins/grin.gif i will just tell the cops that they are my harmonic defibulator plates.
  16. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    There is another option Allied makes a 17" rim with the safty bead that is only 1/2" bigger than a 16.5 and is a good choice with a 37" tire. They are also avalible with a bead lock. Would be the same as running 35's with a 15" rim.
  17. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I'd have to say it was the slicks that got them busted! That is illegal in every state.
  18. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Zakk, you've HEARD of it, or you KNOW the people? I've searched the CA vehicle code pretty thoroughly for a law saying that beadlocks are illegal and have yet to find anything. Also, the Hummer beadlocks are not legal anymore if they've been modified, since it's illegal to modify a rim. </font>
