izzit a 700??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Innerpiece, Sep 13, 2001.
  1. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    Hey all -- I recently replaced the tranny filter on my 700R4 ... when I pulled the pan I noticed lots of wires, solenoids, etc right there on the bottom of the tranny. I have a TV cable that's hooked up to the plunger dealie in the tranny and the filter for a 700r4 fit as well as the new pan gasket (16 bolts, squareish) .
    Is this 700R4 standard or do I have some other type or newer tranny? BTW, I have 2 switches "attached" to the brake pedal ... one is obviously the brake lights and I think the other is for no-op cruise ... but could that be for the lockup on a newer ####E tranny? Also -- I seem to have 5 forward gears! (although unverified with a tach, I can count shifts to 5th and the RPMs seem to agree)
    What the hell do I have there?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Thats a 700r4. The 5th one you are feeling is the torque converter is locking up, not shifting into another gear. All of them do that with the lock up converter.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Innerpiece
    Feb 22, 2001
    145
    yeah -- but I think I'm getting that extra shift or the lockup in 1st gear ... on an 87 ... I thought that was before the newfangled electronic trannies.
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    700r4 trannys are eloectronic. The only difference between the 700r4 and the 460LE is that the 460LE uses an electric speedometer, and the 700r4 uses mechanical speedo. Also the 460LE is shifted by the computer, and the lock up is electronic not vacuum operated. Most of the internals are the same
  5. 90idahoblazer
    90idahoblazer 1/2 ton status
    Jun 24, 2001
    183
    Idaho
    not true....I have a 700R4 witn a electronic speedo......1990
  6. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    It isn't actually a 700r4 in your '90 model, it is a 4L60. The 4L60E is the electronically controlled version.
    '85 K5 : Run it til it breaks, then fix it and go again!
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    According to the Spec section, the 4L60 was introduced in '91. My '90 Jimmy has an electronic spedometer.
    Derf00
    "A WISE MONKEY NEVER MONKEYS WITH ANOTHER MONKEY'S MONKEY."
  8. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Derf00
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    4L60 = 700R4, both are identical
    4L60E = Electronically shifted tranny that is otherwise identical.
    None of our trannies have speedometers, they're in the transfer case.
    Tim
  10. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i sense tension. actually, niether my trans, nor my trnsfr case have a speedo, but the swim team does, and while im on that subject, how come the mens swim racing bathing suits are much more erotic than the women's, that's just not fair.
    Tork DSR
    I just got a winch, it takes the fun out of things.
  11. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK. That was weird. (sniff sniff) Does anyone smell FARTMAN?
    I hope your not FARTMAN, we had a hell of a time getting rid of him! ( and his bad jokes )
    I get all the excercise I need pushing my luck![​IMG]
  12. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    I know for a fact that my 90 has a 700R4.......The TV cable controls shifting...not the speedo...The 4L60 oil pan is shaped differently the the 700R4 also
  13. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    the 16 bolts and a square pan is a good way to identify the 700R4
