J code injector pump on a C code engine.
Discussion in '1982-Present GM Diesel' started by josephn, Jul 17, 2002.
  1. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    Can you use a J code injector pump on a C code engine with no problems? Is it calibrated differently than the C code one?
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I think there the same. Maybe different adjustments.
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    From what Ive heard, all DB2 pumps for 6.2s are the same, just different leaf spring adjustments for the plungers and maybe a different automatic advance unit (possibly calibrated for different timing curve). Those are really the only two things you can change to get more performance out of a DB2 I think.
