J**P Steering Shaft Conversion Question
Discussion in 'The Garage' started by ARAMP1, Sep 21, 2006.
  1. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I couldn't seem to find this one by searching...
    Which Cherokee steering shaft will work on a later style steering box; the 88-96 one or the 97-01 one? Or, are they basically the same?
  2. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Can't help ya, but I'm going to ask the opposite of that, which one will work on the older steering box?
  3. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Surely someone here should know.
  4. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    I got one from a 95 but havent tried it yet.
  5. clstolten
    clstolten 1/2 ton status
    Sep 4, 2002
    356
    I pulled my shaft from a 86 cherokee. I used it on an older steering box, but I understand that this is hit or miss, because some of the older boxes have larger splined input shafts. The newer straight axle trucks all have the smaller input shaft on the steering box's from what I have seen. I had to find a newer steering column that had the square output shaft, as the earier columns had splined outputs. My truck is a 74. My wife used to have a 97 Cherokee, and the steering shaft on it looked like it wouldn't work on our trucks, but I can't verify that.
