Jack up truck to pull driveshaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by The Loner, Aug 5, 2002.
  1. The Loner
    The Loner Registered Member
    Aug 1, 2002
    13
    Davis, Ca
    In the haynes manuel the first thing it says to do before pulling the rear driveshaft is secure the rear axle on jackstands. Is this really necesary? I would rather have them on the ground so I can use the parking brake. TIA--B
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Not neccessary, just chock the wheels to make sure that the truck isn't going anywhere. </font color>
  3. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I took mine out, Well it took its self out with the wheels on the ground /forums/images/icons/smirk.gif . I also put it back in with all the wheels on the ground. I think it says this so that you won't crawl under the truck while it's balancing on a jack /forums/images/icons/wink.gif .
