Jammed trip meter...
Discussion in 'The Garage' started by kp texan, May 30, 2005.
  1. kp texan
    kp texan 1/2 ton status
    Sep 8, 2003
    211
    Corpus Christi, TX
    I searched all over the forum for a post on this subject, to no avail. The trip meter on my new K5 (new to me but it's an '88) seems to be jammed since I can't press the reset button in all the way to reset it. I'd like to use it to track tank mileage but I dont want to break the thing by putting too much force on it. Have any of you guys had this problem and, if so, what did you do to fix it? :)
    Thanks so much,
    Wes
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    i had the same problem........
    i still have the same problem. :mad:
    good question, and i hope someone can answer it. :cool1:
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Push and turn ;)
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    :grin: Ditto ' it can be a pain but it will turn over with a little persitance
  5. kp texan
    Sep 8, 2003
    211
    Corpus Christi, TX
    Thanks for the help. Looks like I'll just have to work it a little more. :)
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Let me know if that works, mine has been stuck since the day I bought the truck. Nothing seems to work.
  7. BlazerFarm
    BlazerFarm Texagonian Premium Member
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    Yeah, my 90 is a pain in the butt to reset. I have to push in and turn clockwise. Depending on what the numbers are set to I may have to push and turn about 9 times to hit all zeroes. It isn't easy. What a bad design.
  8. dyeager535
    26,976
    Pushing it in and putting a little side load on it typically works. It isn't a push/reset setup as said, it's a push/turn deal.
    Yes, poor design, even when they work "right" they aren't very convenient. Then again, it's either that, or no trip odo.
