JB conversions, why no SYE for 208??
Discussion in 'The Garage' started by 85mudblazin, Oct 18, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    What is the real difference that would prevent them from making a SYE for a 208?? Why did they pick the 241?? Seems like a 208 would be a much better choice just because there are WAY more 208's then passenger drop 241's. They could make alot more money in my eyes unless there is somehting in the case its self that would prevent it from happening. Anyone want to shed some light??
  2. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I was wondering the same thing awhile back.. anyone have answers??
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    To be honest I see no reason other than the fact that 208's have this stigma of being "weak" cases while 241's are god's gift to those who can't afford a doubler. :rolleyes:
    My real question is why the kits are $100 cheaper for 231's than 241's.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    The cases them selves are made out the same material and they are both weak for that. Only plus to the 241 is the little bit of lower gear and maybe the oil pump is a plus.
    Semms like it would be easy to just make a short shaft for a 208 just like a 241.
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Should this be moved to the vendor forum?
    But i have a 208 and a sye would be great.
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Yeah, they're extremely similar, hence the rolling eyes. Like I said, the 208 is viewed by many as weak, I don't know why. The cases are aluminum but I don't plan on high centering my rig on it either.
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Fords had fixed yokes on their 208s. Find one and start awapping parts.
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    requires aluminum welding and is longer then a 241 with a sye.
  9. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Sounds like you need a swap.... No, you can't have mine! :D
  10. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Do the shafts form the fords fit? I know jeep, dodge, and ford 208's are all fixed, but i didnt think any of the shafts lined up. especially with a 700r4.
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    This is not the point, sure you can get a dodge case and all of that but why when you can make a phone call and order a SYE that will bolt right on and be all new parts.
  12. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Because if everybody's 208 case is a fixed yoke but ours, they probably wouldn't sell too many of them. Besides, by the time you pony up for a 241 SYE you can rebuild a 205.
  13. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im working on making a sye for a 208 using stock chevy parts. i just need to get the tooling and sit down and do it.
  14. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Hmmm..... I was able to find a SYE that is a direct swap in. :thinking:
    Oh .... wait a second.. that's right... I have a 241. :p:
    Wheres the :kickballs: icon when you need it. :D
    Honestly, I don't know why they don't make it either. I thought they were, for the most part, the same animal. But there must be something different. I would think it would be in thier interest to make the 208 before 241, .... I would assume that there are more 208's out there.
    However, I do have to admitt to you, I'm glad they at least got one for the 241... ;)
  15. jmd4x4
    jmd4x4 1/2 ton status
    Apr 4, 2005
    137
    Rosenberg TX
    No, a ford shaft will not fit a 208, but a dodge shaft will along w/ a ford rear housing. When I get my axels replaced I will be making a SYE for my 208. If it works I will let yall know.
    later
    jmd
  16. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I've heard the planetary gears of the 241 are stronger.
  17. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    Doesn't the 241 have a larger chain? I've never owned one, so I wouldn't know... but I thought I had read that once.
    j
  18. jmd4x4
    Apr 4, 2005
    137
    Rosenberg TX
    That I can not help you out with, all I know is most of the time only the rear housing brakes on a 208, whitch in turn usally cracks the case. So making it shorter will help that out a bunch. Plus there are so many 208's out there.
    later
    jmd
  19. jmd4x4
    Apr 4, 2005
    137
    Rosenberg TX
    No the 208 has a bigger chain, it is 1/2" bigger than a 241.
    later
    jmd
  20. afroman006
    Aug 21, 2002
    2,876
    Yah finding parts for a passenger side drop 241 is a bitch! I have to say despit strength issues a SYE for a 208 would be tits!
