JB Weld for a thread sealant?
Discussion in 'The Garage' started by pvfjr, May 14, 2006.
  1. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Why not.
    When I decided to try and tap my own steering box for hydro, I kinda messed up the first hole. I started the hole in the right spot, but angled the bit a little in the wrong direction and didn't hit the passage very well. So I figured since I have a spare box I can clean up if I need to, I had nothing to lose to try and fix my mistake. So I backed the drill out and drilled back into the same hole at a different angle. Obviously things got a bit oblong, but it tapped fine. The fitting screws right into it nice and securely, but there was a bit of a gap left that caused for some leakage. So I cleaned things out, got the fitting barely threaded in, slopped some JB Weld on it, and tightened it up. I'll have to see how it holds, but I think it should be fine. At least I didn't screw up my friends box when I tapped his.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya it will hold im sure
    on another note, blue loctite works real good for thread sealant for air fittings, little more expinsive than teflon tape, but it works real good.
