JB6 Brake System what is this?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Jan 22, 2003.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    On a 14 bolt ff what is JB6 Brake System? It lists this in the parts book for brake shoes. What is it?
  2. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    That's the option code for the brake system.
    If I remember correctly the JB6 is a non-hydraboost system with the 13" shoes.
  3. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I thought hydroboost just dealt with the power steering pump and brake master cylinder?
  4. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    The hydraboost system replaces a vacuum booster on a 1 ton or diesel application. It provides the power assist via hydraulics for the brakes, it uses the p/s pump to provide the hydraulic pressure.
    The JB6 code is a GM option code for a combination of parts: **I think** vacuum assist booster, larger master cylinder and 13" rear drum brakes. The JB8 code is for the hydraboost system with 13" rear drum brakes.
    Here is a break down of the brake option codes (unfortunately the descriptions are a little vague):
    JB1 : BRAKE, MANUAL, DISC/DRUM, 4300 LBS
    JB3 : BRAKE, POWER, DISC/DRUM, 4600 LBS
    JB5 : BRAKE, POWER, DISC/DRUM, 6400 LBS
    JB6 : BRAKE, POWER, DISC, DRUM 7200 LBS
    JB7 : BRAKE, POWER, DISC, DRUM 8400 L85
    JB8 : BRAKE, POWER, DISC, DRUM 10000 LBS
  5. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Thanks for the info.
