JB7 brake system question
Discussion in 'The Garage' started by mechted, Sep 5, 2005.
  1. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    does anyone know which port on the master cylinder is front and which is rear on the JB7 brake system? Is it the large line (0.25", rear supply) in the front or rear port as the cylinder sits in the vehicle?
    The lines seem to changed from the way they were... and inspection of other trucks around here has yielded more questions than answers. (1 each way...)
    this was a 85 C10 with plastic reserviors and is now a 85 C20... the lines seem to have switched front to rear from the previous cylinder? can that be right?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    just swap the lines to the right size ports, my brothers 79 jimmy had to be done that way when he added a 3/4 ton cylinder off the same year suburban.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    front portion of the MC is for the rear brakes, rear portion is for the front brakes. has been that way on EVERY GM truck i've ever worked on.
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    there is a difference between 1/2T's and 3/4T's.
  5. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    The front resevoir on master cylinders is usually the the biggest one , the rear being the small one. Disc brakes require a greater fluid volume for activation. Look at the sizes of the pistons in a caliper. Then look at size of a wheel cylinder. Drums get a lot of their power from the self energizing effect.
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    i know this. i manage an auto parts store I have catalogs full of this stuff and about 60 of em on the shelf. I'v also done 3 4wheel disc conversions, and 4 half to 3/4 ton swaps. I'v also done manual to power swaps.
  7. mechted
    Oct 19, 2003
    765
    Granbury, TX
    thanks, thats what I wanted to hear
  8. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Yepp, I took the one off my Blazer and replaced it with a 3/4 ton model. The front res. was smaller and for the rear brakes, and the rear res. was larger and for the front brakes.
