JB7 Conversion?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by btolenti, May 25, 2006.
  1. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Anyone know if a JB7 master will bolt onto a stock K5 power booster? I have seen posts saying yes, it will bolt right on, and no, it will require the JB7 booster.
    My master has a small leak, so it needs to be replaced, so I figured if I could upgrade....I should.....
    I have an 86 K-5, and was considering a master from a 86 K20 with JB7 brakes... From what I can tell, the difference, if any is booster pushrod length, but like I said, some have posted that the 3/4 ton master swap is a bolt on deal....
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    jb7 should bolt right up, jb8 wont (hydroboost)
  3. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    is there any increase in stopping power going to the 3/4t master on 1/2 brakes? or is it just a "this will also fit" kinda deal. i could see it helping maybe if you've done a 3/4t or 1t axle conversion, but what about an otherwise stock truck?
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    everything that ive read say the master has a bigger borer and wont fit...:confused:
