Jeep Junk
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SnakeEyes, Apr 19, 2000.
  1. SnakeEyes
    SnakeEyes Registered Member
    Apr 18, 2000
    37
    Colorado
    OK Folks, I am a Chevy man, and then some! HOWEVER, I have a poor friend who needs clutch job done on his Jeep CJ7.
    :It is a 1989 with a manual 5 speed. As I understand it, there are 2 flavors of tranny available and I’m not sure which flavor he has. The question is this. I’ve got to remove the mess to get at the clutch assembly, of course, and I ‘m not sure how to get the “stick” off the stub coming out of the tranny. Any input here???
    I’ve had this (similar) post on a Jeep BBB for a week and got “0” response. Those folks are about as helpful as a Rubber Crutch. Wonder if they actually know anything? Any body out there done this job!???
    Thanks for the help!!!
    Snake
  2. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    I'm sure if you called the dealership they could tell you, or a local shop that works on 4x4's or manual transmissions.
  3. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    It's probably similar to the GM style. The cap the holds the stick in pushes down and rotates. The stick should come out. I usually use the handles of channel lock pliers to push down and twist to remove the stick on my 465 4spd. Good luck!
    Shawn
    <font color=blue>87 K5</font color=blue>
    <font color=red>454, 6", D60, 14 blt, 465, 205</font color=red>
    www.off-road.com
  4. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    The jeep guys may have been confused. A 1989 would be a Wrangler. 1986 was the last year for the CJ-7. Don't know what tranny that is, but it should be a Dana 20 t-case.
    Blazin' in Flagstaff
