Jegs cage beginning install pics. Update 7/26/05
Discussion in 'The Garage' started by MNorby, Jul 16, 2005.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    Got the main brace in and tack welded last night. Monday I'll take it in and get the halo and front braces made to my specs. Here are some teasers. If anyone is interested I can do a write-up on the install. I have taken a bunch of pics of each step already.
  2. gstuck3
    gstuck3 Registered Member
    Mar 15, 2005
    51
    Twentynine Palms, CA
    Nice
    It's looking good so far. I'd love to see a write-up. Does it come with plates on the bottom of the tube? Can it be bolted to the floore with those sandwitch plates?
  3. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    it comse with 6x6" floor plates that are designed to be welded in. I drilled a 3/8" holes in each corner and bolted to floor and will prob also do some small welds too.
  4. 82dieselburb
    82dieselburb 1/2 ton status
    Jan 6, 2004
    105
    central Florida
    Looks good so far,nice tight fit :D
    I'd like to see pics when completed.
    Nice half doors,I like the handles you put on them. :bow:
  5. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    the door handles I used are kenworth door handles and I reversed the way the linkage works so you putt up on the instead of having to push down. Perfect fit and we have a bunch at the shop. Will hopefully have more done on the cage early next week.
  6. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I want a writeup on those doors :D
  7. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    the doors I took some spare doors. on the inside I cut the whole rippled part out and the outside I just cut they shape I wanted. I then took 3/4" sq tubing and made a frame on the indise so I could plate the openning on. Took the semi latch and mounted it, painted and installed. I can take some close up pics when I go back to the shop.
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I think we need write ups on both the doors and the cage....it might take some time....but just think how many people you will help!!!
  9. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    I'll try to get some more pics of it all this week. I should have taken more pics of the doors as I was building them but I'll take some close ups to give ideas.
  10. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Yes you should have taken more pictures... didn't you know that they would be so poplar when you were done? Think you should just build up a few extras for us jealous members here :D
  11. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I agree.. that would be awesome to have a half door right up. Those are some nice lookin ones too. The cage looks like its turnin out well also.
  12. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Please do a write up. The jegs kit is nice.
  13. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    well, I built some mounts to make the cage bot to the back of the carb above the rear window so I can make a plate and sandwich the cab and continue the cage to the bed. I took a few pics but forgot my camera at the shop :doah: :doah: :doah:
    I will post up tomarrow night.
  14. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    A write up would be real cool. i will be doing this
    mike
  15. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    a pic of the brace to be able to go through back of cab.
  16. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    more done
    Got the halo bent and installed tonight and got the front supports bent and will try to install tomarrow night. A few pics:
  17. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Your not welding the entire cage with those tack welds are ya?
  18. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    no, just tacked the base structure of it together so I could make sure it is all gonna work they way I want and then I will fully weld
  19. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Looks to be fully tack welded to me :whistle:
    Stop worrying about how your welds look and just weld it right ;)
  20. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    I'll take a pic of the welds for the halo tomarrow and see what you think
