jet ski motor problem help please
Discussion in 'The Garage' started by surpip, Dec 13, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    this is a question from my little bro, he got this jet ski for 20 bucks, it would be cool ifwe could get it running right.....
    when you give it gas when it is hot the motor acts like it is hitting a rev limmiter at a really low rpm, but its fine when its cold, i checked the reeds and carb and they are ok its a 2 cylinder 500 2 stroke out of a jet ski
    thanks alot for any help,
    dale
  2. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    I'd pull a compression test on it (should pull 130-150lbs. I think).
  3. gforce
    gforce Registered Member
    Nov 25, 2002
    9
    West Columbia, TX
    Check The Wear Ring Around The Impeller And The Leading Edge On The Impeller. See If Either One Is Damaged Or Worn Out.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    alright cool, anything else it might be?
  5. ryguy
    ryguy Newbie
    Dec 14, 2004
    Cali
    thanx for the help guys dose anyone ecle have any ideas?
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    kinda funny how my litle brother is dooing better than i ever did in HS and he still spells worse than me:rotfl: :rotfl: :thumb:
