jets and metering rods ona q-jet
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Sep 17, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Has anyone changed thier jets and metering rods on thier q-jets to better suit engine mods? Im just wondering what you changed to and how it changed the performance. Im particulatly interested in people that have recalibrated it to match intake, cam, and headers
    Check out my 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a>
  2. dyeager535
    26,977
    I've screwed around with power piston springs (primary metering rod vacuum) and rods/jets.
    None of those mods made much of a difference. Especially in the MPG department.
    I've put 350 Q-jets on 454's. 350 Q-jets on 403's, 305 Q-jets on 454's. All without mods to the carb, ran fine. I *did* play around with the secondary metering rods and hangars, since that is where all your power is made when you are on the throttle.
    You could also play around with the primaries, leaning them out until you get some surge when cruising, then richening back up a bit.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
