jimmmy update
Discussion in 'The Garage' started by chevyguybc, Jan 20, 2007.
  1. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    well i figure its update time
    heres some pictures of the messy shop, busy building working and partying!!:wink1: :wink1: no time to clean up:rolleyes:
    anyways the dana 60 is resting until i get the bushings in tommaro night....
    the 64s are awaiting the custom reverse shackel... blocks are in for show ,
    so i could mock up the 64s and the reverse shackels/shackels im builing...
    , the shackel reversal is going to be 5.5 of lift. and the shackel is going to be 6.5 long.. this should be close to 8 inchs of lift with an add a leaf in the 64s with no blocks of course...
    also building custom front crossmembers...( in jigs to sell them publicly)
    also need clutch parts, motor( 454 coming from a friends 74 blazer, he wants 350..)
    then rear driveshaft.. and tons of metal work on the tub itself,
    should be done by march april!
    and heres the before pics, and then last summer in the next post
    how do you like the trees and 4 inch lift, it had 305 automatic, 10 bolt and 12 bolt, then it went dana 44, 14 bolt, 4:10s, and it was lifted 52s and stock rears, now of course the 64s are going in, and eventually ill go with lifted 56 fronts i think
    now its 4:56 1 ton, rear disk, 454, 4 speed/205, crossover, 2.5 dual flowmaster, and 38s,
  2. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    pictures
  3. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Wow, That's pretty tight fit in that shop. Do you have any room on either side of the rig?
    Cool plans you for your rig!
  4. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    tight shop, maybe the picture made it seem so, heres apic of my old truck i owned in 2003 in the same shop, it was 4 inch susp 3 inch body, , 37 firestones, 350 4 speed, 4:10s
    about 5 feet each side seems big to me
