Jimmy/Blazer Tailgate adjustment
Discussion in 'The Garage' started by Ledzoso, Mar 5, 2005.
  1. Ledzoso
    Ledzoso Registered Member
    Feb 11, 2005
    15
    Midland, Tx
    My jimmy tailgate is having problems. I have the tailgate with the electric window(unsure if different from manual). There are two problems that may actually be the same. First, when I try to set the tailgate down, I have to push inward, with much effort, on the tailgate to get it to disengage. Second, I have to push inward on the middle section of the tailgate to get the window to come up? Down is not a problem, just up. My hayne's book offers not adjusting techniques. What have you guys done??? Thanks ahead........:mad:
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    You should be able to loosen your latch catches on both sides of the bedside and move them forward a bit. That way the gate will spring loose when you pull the release.
    As far as the window goes, only way to know is to take off the cover and see whats going on in there. Lots of little problems, mostly rust.
  3. k51989
    k51989 Registered Member
    Sep 19, 2003
    93
    Mishawaka, Indiana
    i used to have lots of problems with the tailgate until replaced the rotted tailpan. now i just have uneven gaps. lol.
    seeing as how your from texas i dont think you have the same problem i did.
    i know the 8 bolts(4 on each side) that hold the gate to the tailpan has some slight front to back adjustment. good luck.
