jimmy not turning over wont start?
Discussion in 'The Garage' started by nickdubrule41, Sep 29, 2005.
  1. nickdubrule41
    nickdubrule41 Registered Member
    May 26, 2005
    27
    massachusetts
    hey guys im having some trouble starting the jimmy.some times it it will start like it should,other times you turn the key and the power acc comes on but when you go the rest of the way to engague the starter something under the dash near the gas peddle makes a clicing noise and all the power goes off.or if you turn the key to the acc and try to use the power windows or locks the same thing happens,it makes the click noise and the power shuts off is there some kinde of relay or fuse that could be doing this?? thanks guys
  2. wildbilzrydn
    wildbilzrydn 1/2 ton status
    Jun 27, 2005
    118
    Joliet, IL
    Well, it could be that you have a loose positive battery terminal, I've had cars that when you turned the key, the accessories worked, but when you turn to start it "clicks", but at the terminal. If your terminal(s) is/are good and tight (cant move it on the post when you try to twist it) it may be the ignition switch and I think it's mounted on top of the steering column and actuated by a rod. You may have to drop the column to change it.
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    im thinkin ignition module or badly coirroted cables....
