jimmy running rough after hydrolock
Discussion in 'The Garage' started by az ranger, Jul 3, 2004.
  1. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    after draining most of the fluids and packing wheel bearings I took it for a spin and it has a bad hesitation under acceleration I am thinking maybe my gas has water in it now since the tank was under water for a while or maybe the spark flugs are fouled I havent changed them yet, any other suggestions?
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I would drain the gas tank and also replace the fuel filter
  3. johnc
    johnc Registered Member
    May 6, 2004
    68
    O.C., CA.
    did you check your distributor for water??? /forums/images/graemlins/dunno.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Pull your spark plugs and do a compression check. Hydro locking an engine can bend connecting rods, break pistons and bend valves. If you have bent valves a compression test will show low or no compression in however many cylinders you have problems.
  5. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    If you still suspect water in the fuel, you could use a few bottles of fuel system drier (Heet or Isoheet). This should work unless there is a LOT of water in there.
  6. az ranger
    May 9, 2004
    139
    Safford AZ
    thanks, for the replies. I heard of Heet from a friend of mine, oddly enough he is from Alaska too, must be a common problem there.
    thanks again
