Junk driveshaft
Discussion in 'The Garage' started by sickquad, Sep 26, 2004.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Anybody know what it takes to pull apart the slip fitting in my driveshaft? It's sloppy now from my exploding rear end situation. I have a 203 t case so the slip is in the shaft. I'm not sure if the flange holding it together just pulls off or what.
    -Chris
  2. diesel4me
    Jul 24, 2003
    17,573
    943
    Massachussetts
    You have to unscrew the "ring" near the end of the slipyoke with big pliers like waterpump pliers--then you should be able to pull the slipyoke off--it might be stubborn,there is a seal inside,also rust can make it hard to pull off.I've had to chain a few to an immovable object and chained the driveshaft to my winch or come-a-long to pull them apart.
    I still have that 12 bolt posi rear in the parts pile if its any use to you--I'll be scrapping it and much other stuff this week,so post back if you need it. /forums/images/graemlins/crazy.gif
