Junk yard find (PIC) (UPDATE)
Discussion in 'The Garage' started by MTBLAZER89, Jan 24, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Kinda confused. This was one a mid 70's bone-stock K5 without crossover /forums/images/graemlins/confused.gif Already milled and tapped. Oh well cool for me /forums/images/graemlins/thumb.gif The other thing that confused me is I though flat tops had tie rods that came up from the bottom. Oh well cool for me /forums/images/graemlins/thumb.gif
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Re: Junk yard find (PIC)
    Sweet deal Brian!!
    So did you buy that up!?!?!!? /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif
    My stock flat-tops have the TRE's coming in from the top like the pic /forums/images/graemlins/thumb.gif.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Yeah thats the way the tie rod is from 73-75. The tie rod end was bent down to clear the springs. But, GREAT DEAL on the pre studded flat top!! Thats a find!!
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    So did they come "stock" that way or did somebody do it?
  5. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I have never seen a Chevy with the passenger side studded. I have heard that some dodge D44's were set up with steering on that side. (I think it was dodge.) But D44 knuckles will exchange from some axels to others. Maybe somebody replaced the knuckle and thats what they found to fit. Either way, your 100.00 ahead on the crossover!!
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah sweet /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    No I didnt buy it YET. I am gonna go out on Mon. and take them off. Think I can use my 10b tie rod with those knuckles??
  7. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,003
    194
    Santa Maria, CA
    You probably should get both knuckles so the tie rod mount on the top.
  8. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    no, It will most likely hit the spring. Use those early tie rods. Unless you are gonna run a z-rate up front. I used my 10 bolt tierods, But My springs have a decent arch to them AND i have a z-rate. I would grab the tie rods, just in case.
  9. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    grab both knuckles, I dont know how that tie rod isnt hitting the springs but hey you never know. I know with my crossover using flat tops i hit the springs up front so i had to drill out the tapered ends and go with 3/4"x7/8" rod ends for the tie rod.
  10. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I know it's hard to see in that photo, But the stock tie rods are bent down so the long rod clears the springs. Thats why I suggest saving them.
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I have a '75 D44 I used a 10B tie-rod for about a year until the captured TRE was shot. The knuckles are top load and the rod was not a drop style. It does rub certain springs more than others, nothing horrible. I don't believe a rock rod would clear however. I now have shims that moved the springs away from the rod.
    Hope that helps
  12. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Thats my plan along with moving the axle 1" forward
  13. NetBlazer
    NetBlazer Registered Member
    Apr 23, 2001
    90
    Littleton, CO
    Is it lifted? If so you may get away with the flat tie rod. I did on mine and it's close, but it can work. See my reply and pics in This thread
    Good luck!
  14. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah My K5 has 4" Superlift's up front, and it's getting a 0-rate along with this x-over swap. /forums/images/graemlins/thumb.gif
  15. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I went out today to pull the knuckles and the guy behind the counter said $5 a piece for GM knuckles /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif I didn't get it all the way off cause I got there to late and they closed, but I am gonna go back early tomorrow and get them both and the tie-rod, and maybe some other stuff since they are giving it away /forums/images/graemlins/thumb.gif
  16. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Wow, what a deal Brian!! /forums/images/graemlins/bow.gif $5 is CHEAP!! Snatch up everything you can for those cheap prices!! /forums/images/graemlins/waytogo.gif
  17. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Well the guy didn't know what Knuckles were when he said $5 so I had to pay $15 a piece Already milled and tapped with studs /forums/images/graemlins/thumb.gif I also saw about 25 more sets while I was there
  18. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    you saw like 25 sets of milled and tapped pass side knuckels??? hmmm would you be interedsted in buyin a couple and hipping them??9 for a price of course?
  19. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    No the other sets weren't milled and tapped /forums/images/graemlins/eek.gif Just flat tops lot of them are Jeep knuckles.
