Junkyard score today!
Discussion in 'The Garage' started by Ryan B., Jul 2, 2005.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Went to pick and pull today..
    an hour or two of wrenching yesterday got me a 32 spline 203 and the adapter.
    Today i went to another yard and pulled a 454 out of a late 80's dually work truck. Gas and coolant were still in the lines so this big block should be a runner. :thumb: 90 degree weather i was sweating like crazy, got a sunburn too.
    Scored the 32 spline 203 (for a doubler) and the COMPLETE 454 for under $300 out the door.... :wink1: :whistle:
    and i can still get core charges back..
    guys were asking me if i worked there.. and how much if i pulled an engine for them... lol.
    Can anyone get me any information on these head castings? 14081045
    All i'm finding is " 78-87...oval...OPEN...454 ".
  2. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    That number isnt listed in either of my books sorry. Sounds like a really good score though.
  3. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    Mortec lists them as
    78-87 oval port open chambers and 454
  4. 74 chev
    74 chev 1/2 ton status
    Sep 30, 2004
    159
    Concord,CA
    you piss me off i want just a big block for that much.
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Well, if you can figure out how to ship this 600lbs to you, and offer me a few hundred dollars.. it could be yours. :wink1:
  6. icer97
    icer97 1/2 ton status
    Jun 15, 2005
    116
    Missouri
    "it would be cheaper to just install a dana 60 in front" -mudhog
    I tell my friends this all the time, but yet they insist on keep building those dang 10 bolts! They are still looking for a $200 dana 60. Good luck. Nice score bro, ill go with ya on your next voyage! :D
  7. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    so...r u going to put that bb in your blazer?
  8. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Oval port heads
    I'm pretty sure they refer to those as "Peanut" heads. Just plain Jane GM BB truck heads. Should do you fine unless you're going to get really radical with the engine.
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Most likely i will sell the 454 to pay for other projects.
    I need to pull the oil pan and see if its a 2 or 4 bolt main.
    The only way that BBC would replace my TPI smallblock would be if it was a 4 bolt main and it got rebuilt with a stroker crank, afr heads and multi port injection. $$$ :wink1:
  10. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Ryan, how'd the th400 look? Which PNP was it?
  11. LongIslander26
    Jun 25, 2005
    256
    Ok
    Boy! You want alot for your 300 bucks! (AFR heads, stroker crank, fuel injection). If it's in good shape, you can probably get good chunk of change for it, especially if it's a MK IV block that can use a mechanical fuel pump. Chevy and most rebuilders are getting anywhere from 500- 1,000 bucks just for a core charge on those. :cool:
  12. Ryan B.
    Jul 18, 2001
    5,693
    CA
    haha! i was saying i'd have to rebuild it and those are the goodies i'd want to get before swapping it in my k5.
    The th400 looked good, still had gas and coolant in the lines so i'm thinking it should run. i was at both san jose yards. both trucks i pulled parts from had 4x4 case th400's. if i didn't have so many parts laying around i probably would have pulled one of those trannys also.
    I sold a pos 2 bolt 454 for $400 so i know this ones worth at least $500. :thumb:
    Hey PeteH i saw a 4.10 ratio 8 lug 3/4 ton 10 bolt front axle up at the newark pick and pull.. its under a red suburban in the first row.
    Don't know if your planning on going lower gears and 8 lug.. but i figured i'd let ya know.
    A few weeks ago we got my buddy a set of axles 14FF/ D44 8 lug.. with 4.10's for $198 out the door for both on half off weekend. :pimp1:
  13. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
  14. The Butcher
    The Butcher 1/2 ton status Premium Member
    May 17, 2005
    431
    43
    Texas. In a van, down by the river!
    That's phenomenal. The guys at the yards here must know what they are sitting on b/c the bastards want $1200-$1500 EACH for a D60 or a 14Blt and that's if you pull 'em. And I'm not even talking brand new axles! Used ones!!!! :mad:
  15. richheezee
    richheezee 1/2 ton status
    Dec 29, 2003
    116
    San Jose CA
    Ryan, are there any other PnP's other than Monterey Rd. and Commercial? Or are there other hunting spots that you prefer? :D
  16. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    There is one on san leandro blvd
    880 north,get off at 98th street (east) to san leandro blvd turn left go down IIRC one light anfter that light it is on your left side of the street..
