junkyard steering boxes
Discussion in 'The Garage' started by Paxx, Jan 14, 2004.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    When I go to the local pick a part how would I tell if the "new" steering box is good or not? Also what years of box should I be looking for? I have a 78k5.
    Is there an upgrade year or model? I heard that there is one called an 808? /forums/images/graemlins/crazy.gif? that would have a 76 cast somewhere on the housing that is supposed to be an upgrade. Any truth to this?
    thnx
    ~Max
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    First off I bet you will have a much harder time finding a 4wd box but they will probably have a few. In 79' or 80' GM wen't to a different style fitting thatn the earlier ones. They are the same boxes though far as I know. When you find a 4wd box look at the fittings and if the holes are deep than it's the early style, if the holes aren't deep than it's the later flare nut style. As far as picking one that is "good", well I picked one out, looked it over and tried to see if it had signs of leakage during use, otherwise it is a guessing game. I was lucky enough that I got one that didn't leak but with big tires it doesn't take long and they are leaking. My "new" box is starting to leak after only being in use on my truck for about 5 months.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Thats funny, I've still got the original box on my truck, no issues with that.
  4. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    how hard would it be to switch fittings?
  5. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    They changed to flare fittings in '80
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You can't change the fittings. If you wan't a later box than you will have to convert the whole system over. It will take a later box, pump, and lines. I would just find an earlier box like yours.
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You are lucky. /forums/images/graemlins/smile.gif
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    flared are before '80 and O-ring new design are '80-up, you can take a box off a late 68 and through 79, blazer burb pickup, 1 ton, etc and is same as your 78 k5 box(p/s)
    boxes in yards would be hit and miss, some worn out and some not, just like on the streets, some worn and some not.
    good luck
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've seen posts of adapter pieces that screw in to convert one to the other, but I don't recall the specifics. You can also get lines made at NAPA or similar with o-ring at one end and flare at the other. Also, the fitting on the pump does screw out and I'm pretty sure they interchange. So, you could just swap the fitting on the pump if you need to use the "other" style box...
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] I was not aware of that. /forums/images/graemlins/thinking.gif
  11. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i wish i would have known that--i had to buy the HP hose and cut the new one, then cut the old one and make a whole new hose because i buoght the wrong box.
  12. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I trashed a pump once due to that whole '80 switch over. I got a new HP line for an '80 it screwed in too far an ruinded the pump. My truck is an '80 by title and vin, but every part I have gotten since is for a '79. The vin is the short one from pre '80 rigs but comes up as an '80. Anybody else have that problem
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    80 is short vin too, 81 up are new 17 digit the vin year digit for 80 is A
    im pretty sure?
  14. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    how do I tell a good box from a bad one? is there a way? and what about that upgrade box any truth to that?
  15. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Like we said, you just have to kind of guess. You can try turning the shaft to feel it and look for leaks but otherwise it's a total guess.
  16. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    ok thnx
  17. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Baddog, you are correct. The fittings interchange between flared and o-ring PS boxes all day long.
