Just a few opinions
Discussion in 'The Garage' started by screamer*145, Oct 23, 2003.
  1. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    Just a new guy checken out the cool site. just to get every thing out of the way I have a 78 blazer stock 400,350,203 part time kit,d44,cp12. as of now no lift with 32's (fender triming). well to get to the point, I just wanted to know what up grade should I invest my money in first. All opinions are welcome thanks! /forums/images/graemlins/grin.gif
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Welcome aboard to the site....Here is what i have found and other's i'm sure will chime in and agree...
    Personally I make sure everything is mechanically sound, No leaks, everything feel tight? Engine run stong, need more horsies, maybe try a upgrade to the ignition system and a edelbrock performer intake. Starts everytime...etc etc.... In MY opinion any problems not addressed before lifting, and other non-neccesitative upgrade will just kick you in the butt before you know it.
    From there,locker, winch, custom bumpers, etc etc....lift and tires will get you places but 32-33 range you can get through most moderate stuff, I wheeled mine hard for 2 years on 31's got a feel for the game and upgraded from there.
    As mentioned once you have your drivetrain engine and main steering braking stuff straight you can hop up to the cooler stuff...
    Good Luck! /forums/images/graemlins/thumb.gif
  3. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    What do you plan on doing with it? Mudding,Rock crawling,Show truck?
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    welcome to the best full size chevy site on the planet! /forums/images/graemlins/laugh.gif
    AFA upgrades, I think there are 2 things we need to know from you first.
    a) what is the rig going to be used for (street, show, rocks, mud, sand, trails, some combo of these...)
    b) how much $ you're looking to invest
    for general build up ideas, thats all we really need to know, but any other info you can toss in there like what size tyres you'd like to run etc would be useful. /forums/images/graemlins/grin.gif
    j
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Please fill your profile out further....I looked there to see where you were from. If you lived in the rust belt, I would have suggested staying with no lift and just trimming the fenders. Makes clearance and removes the nasty stuff while keeping your center of gravity lower. (Wish I had fully checked out the rust thing before ordering my lift.)
    Keep it simple, and welcome to the sight....
  6. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    Sorry about the lateness but I just fineshed rebuilding the carb (Q-jet) I did all the most if not all regular Maintenance so it runs strong. for now it is my DD and trail/mud machine. Yes I do live in the rust belt (MN) but no rust on my K5 went through the body last winter hurculined inside and underneth /forums/images/graemlins/wink.gif. thanks for the wecome guys! /forums/images/graemlins/k5.gif
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Pick the right gears for the combo early on, and get them installed. Sometimes these get put on the way back seat after the other mods are done.
  8. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    wouldent i just be better off getting 3/4 ton gear with some 4.10s ( I dont see the point in wasting money in 1/2 ton running gear), and I know that the front ends are the same if I can find the 3/4 font end it allready has 4.10's and well a 14ff are just great! /forums/images/graemlins/thinking.gif
  9. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    wow your all over it, hurculiner 3/4ton. Youll fit right in here! As far as mud/trail stuff try to keep the centre of gravity low so you can have fun on the off camber stuff, and just get realy wide tires. probly wouldnt go much bigger than 35s for trail work and whith the k-5s shorter wheelbase they can do perty good in mud whith 35s too.
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    If you go 3/4 ton, throw a Detroit locker in the back while you are at it. You will out do many rigs with lifts and larger tires. /forums/images/graemlins/deal.gif
    Welcome to the site. /forums/images/graemlins/thumb.gif
  11. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    ya, I was thinking of a four inch fit and some 35x15. what would be a better tire a tsl swamper or a tsl radial. and has anyone herd of a company coalled Genuine Suspension and if they are any good (saw the add in a four wheeler mag.) /forums/images/graemlins/thinking.gif
    !Thanks! /forums/images/graemlins/k5.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Genuine suspension is the crap that 4WPW sells and is the same as Pro-Comp or Rough Country. They're STIFF too. If you don't mind a rough ride, you'll be fine with them.
  13. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    It would be a good idea to go ahead and brace the area around/behind your steering box, cause it'll eventually crack. Get the weld in brace and the bolt on brace from Off Road Design.
    Will
  14. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I am amazed that no one has said it yet....................a membership to ck5.com is a very valuable upgrade, highly recomended.
  15. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    You are correct sir, going 3/4 ton or so with the gear ratio you need is usually the cheapest and easiest way to regear - with the added benefit of more strength and reliability....Keep your eyes peeled for those 8 lug rims.
  16. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    I shall get the membership to day, as for the steering brace it will be my first hop-upbut do I realy need the weldin one, do you guys think that 4.10 gears will be good for 35x15,also what tire is better and how long will it last the swamper tsl or some ground hawgs.
    /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  17. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    groundhawgs will outlast a LOT of tires because the tread compound is HARD...
  18. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    will they give a harsh ride /forums/images/graemlins/thinking.gif
  19. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
  20. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ] Any bias ply tire will /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
