Just a few simple questions... RTI, leaf springs...
Discussion in 'The Garage' started by ugly_blazer, Aug 22, 2004.
  1. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    A have read several post about 63"? springs. What trucks do these come from?
    What type of vehicle will typically do better on an RTI ramp, a long or short wheelbase? (ex. - K5 or K20 with similar suspensions)
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    63" springs come from 88+ C/K trucks. RTI ramp scores are based on wheelbase, so there's no cut and dry answer to your wheelbase prefrence question.
  3. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    As far as what wheel base will do better on a ramp, None. The way the calculation for the score works, it levels the field by taking the wheel base into consideration.
  4. ugly_blazer
    Apr 12, 2004
    1,214
    Ok, thanks. I remember the post that Tim made where he used a forklift to lift a tire, I may do that since there are no ramps in my area and post the number here for the mathematicians...., there is a formula to figure it out?
  5. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Distance travelled up ramp / wheelbase x 1000 = RTI
    So if you have two rigs diff wheel bases going up the same ramp and they both traveled 75" up the ramp the scores are like this.
    75 / 106.5 x 1000 = 704
    75 / 116 x 1000 = 646
    The longer wheel base scores worse. It should be easier for a longer wheel base to go up a ramp.
