Just a prerunner appetizer
Discussion in 'The Garage' started by Bubba Ray Boudreaux, May 4, 2002.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I'm following a thread over on race-dezert about straight axle prerunners with some awesome info and there's some pictures posted on a soon to be featured in Off-Road truck. Check it out,
    <a target="_blank" href=http://www.race-dezert.com/wwwthreads/files/6-21733-chevyfront.jpg>http://www.race-dezert.com/wwwthreads/files/6-21733-chevyfront.jpg</a>
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Are those National's or Alcans? They look soft and flexy.../forums/images/icons/cool.gif
    Rene
  3. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Neither. A place called Deaver Spring makes them. They are in SoCal and for the last couple of years, dez racers have been giving a lot of good feedback about them because National has been so backlogged and Deaver gets there stuff out fast plus it's quality. Hopefully one day I can have a set of Deavers on my truck. Last I heard, a custom set of springs was about 1000 bucks.
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I had Deavers on the Ford - $980 out the door for 5 leaves double wrapped, 7" over stock, and some killer dual rate coils. Ahh to be single and able to afford the good stuff again/forums/images/icons/wink.gif
  5. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    That is pretty bad, what kind of truck is that and what kind of axle is that? JW
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    It's a 67-72 (not sure which) K10 - the axle is a D44.
  7. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    So what's the biggest difference in that and ours? I'm guessing, travel, spring rate (jumps), tcase???? since they run a lot faster speeds, what else makes them difference within the drivetrain / suspension
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Look at those sweet welds on that shackle pic! Wow.
  9. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    I like how the frame is all plated and the shackles are decently braced too. They aren't playing games here are they?
  10. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Travel, spring rate and axle/chassis beefing are the big ones - the t-case will typically be a 208/241 or some other aluminum case, with drivetrain modifications revolving around horsepower.
  11. i don't think a 208 with the slip yoke would do so great with that much travel. i would think the force of landing a big jump would want to push the yoke up more than in. i guess you could have a long travel yoke made but i think a 241 with sye would be better.
  12. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Most racers actually run slip yokes with relatively long driveshafts - fixed yokes tend to get rammed through the housing. I saw a Scout have that problem at Glamis a few years ago.
  13. really. so does anyone make a long travel slip yoke for a 208 or is that a custome job? good pre runner suspension usually has some seriouse droop so a long slip yoke would be a must.
  14. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    There's variations out there you wouldn't believe - like extra long 2wd E4OD Ford yokes milled to GM output shaft sizes. There's also alot of custom jobs, and even more factory length with custom length shafts.
  15. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Re: Just a prerunner appetizer UPDATE TECH PICS!!!!
    http://www.race-dezert.com/wwwthreads/files/6-21736-chevyrear.jpg
    <a target="_blank" href=http://www.race-dezert.com/wwwthreads/files/6-21737-chevyside.jpg>http://www.race-dezert.com/wwwthreads/files/6-21737-chevyside.jpg</a>
    The last pics that Scoob posted, from Glamis I think, looked like his truck had minimal travel upfront, back the back end had gobs of travel. Is that just an illusion?
  16. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    It does have a shade more in the rear - nothing like it looks like in the pics though/forums/images/icons/smile.gif
  17. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    why is the spring eye below the top leaf and on mine it is above ???
  18. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I believe that is what is called a military wrap. It's said to be a lot stronger than the normal eye.
  19. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    no i know what a military wrap is , my truck has that .
    what i should have asked is why does it look like they put the top leaf in the front upsidedown ?
