Just a quick rear D60 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Overkill, Mar 28, 2002.
  1. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    I have a friend who needs to replace the seals in a D60 rear. From what I could tell in the tech section, it looks like the seals can be replaced pretty much like a 12B, pull the C-clip, pull the shafts, R & R seals, reverse order and all done. Is this correct? If not, what else is there that needs to be done? If it's that simple, no problem. I've done a 12 but never witnessed the inside of a FF60. Any help would be greatly appreciated. Thanks.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    First off if its a Full Floater (FF) there are no c-clips. You need to unbolt the covers on the hubs and pull the axles out.
  3. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    If its a FF D60, then there are no axle seals. The flange of the axle seals against the hub. If that's leaking, then you can just RTV them and it will seal.
    Will
