just a thought....
Discussion in 'The Garage' started by NEK5, Feb 10, 2007.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    right now I`m running 33x14.5 MT Baja Belteds, which are only at 20 PSI, as that`s what they call for....Is it likely that they`re killing my gas mileage?
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    they call for 20psi? where? and yes...
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I believe on the side of the tire, its says max inflation 20psi
  4. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    i highly doubt that. most tires have a max of 60-85....i would think you should run about 30psi....
  5. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Hmm, I`ll run out and check right now...
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Alright, this is what is says: max load 1870lbs at 20psi, load range B
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    are they bias or radial? bias tires dont have as high of a psi rating as radials. i ran my bias iroks at 22psi, max was 30
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Bias
  9. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    mm i see... that could effect it...
  10. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    well a wide tire will definately have an effect on your mileage, as will a taller tire with the same gear you had with a smaller tire...
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Do you think I`ll have a noticeable improvement when I get my new 33x12.5 TRXUS MTs?
  12. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    small one, they're radial as well, so you could run 35 psi and have less rolling resistance in that fact as well as reduced width...
