Just added a new kit.....14 Bolt Axle swap kit for leaf springs.
Discussion in 'Vendor Forum' started by Gravel Maker, Sep 26, 2006.
  1. Gravel Maker
    Gravel Maker 1/2 ton status Vendor
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    The complete 14 Bolt Swap kit, everythng included, Perches, Ubolt plates, Ubolts, Shock brackets, Disk Brake brackets, & a 3/8" thick 14 Bolt Diff Cover. I will add pics of the complete kit tonite.....$295 total
    I have made the Spring & Shackle hangers & Shackles optional because so many reuse the old.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If only you had that a month ago. There, someone had to say it so I thought I would get it out of the way....
  3. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    I've heard it 5 times now.....
    But, we have sold another 5 since we released these. They just make life easier.....Makes it easy when its all in one package......:wink1:
  4. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I was wondering how much should a 14 bolt sf with 4.10 gears cost?
  5. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    A semi floater with 4.10's around here is only....
    $100-150, but a FF with the same is about the same to $50 more, of course that is in stock form.
  6. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    We now have the simple swap kits......
    Just the basics, $120
  7. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    A big refresher, back from the dead!
    Its kind of funny that I haven't updated this in 3 years but it is among our biggest sellers to K5 guys. It was the first and now we make 14 different axle swap kits :D thanks for your support from early on!
  8. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    how much for just the ubolts?
  9. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Here you go...
    Our Ubolts are $12.50 each but the CK510 discount code takes $1.25 off so $11.25 each....2 can go in an envelope for $6, any more than 2 will go in a box for $11.50, thanks
  10. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    Cool thanks I just ordered them
  11. mudslingger
    mudslingger Newbie
    Jan 24, 2011
    maryland
    How much for 4 u bolts (need to be long enough for a 4" block), two spring pads, and do you sell the conversion u joint from ten bolt to 14bolt?
  12. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Those would have to be 12" long but we don't charge extra for them until they are 13" long so $13.25 each less the CK510 discount to bring them down to $11.97 each before shipping. Give us a call to order, thanks.
  13. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Everything all in the same box at a discounted price!
  14. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Just to set the record straight, the other company advertising here that sells parts that look exactly like ours dosen't buy them from us, he used to and now he copies them exactly...
  15. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Dosen't that just pi** you off!
