just another homemade shackle flip bracket
Discussion in 'The Garage' started by bboy, Aug 2, 2004.
  1. bboy
    bboy Registered Member
    Apr 21, 2004
    37
    I used part of a front spring hanger and part of a rear shackle hanger to create this shackle flip bracket. i've installed 56" springs on the rear with the pin to the back moving the rearend back 4". i will be relocating the fenderwells this week. i will try to take pics. bboy [​IMG]
  2. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    NICE!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    so you used both the stock front and rear hanger on a k5??
  4. bboy
    Apr 21, 2004
    37
    that is correct. the outer tab and support gussets are a portion of a front spring hanger. the inner tab and backing plate are a portion of a rear shackle hanger. the original strengthening bracket that was riveted to the bottom of the frame still fits in the new location. bboy
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    How much lift did you get out of it? switching 56's only makes 3" more wheelbase /forums/images/graemlins/waytogo.gif
  6. bboy
    Apr 21, 2004
    37
    [image][​IMG][/image] [image][​IMG][/image] actually the wheelbase thing can vary. it depends on how much forward movement you get by going from a tension shackle to a compression shackle. the pin on the springs going from a 52" to a 56" is different by 4". vehicles using a 52" or 56" rear springs have a common front spring hanger location.
    the lift gained i did not measure exactly. it sits about the same height as it did with the 4" lift springs.
    it sits almost perfectly level with the 52" springs in the front and the 56" springs in the back. it has zero rates in the front and overloads in the back for now.
    some of you may recognize this jimmy it belonged to a guy named brian glass that used to frequent this board. bboy
  7. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    yeah, tx85gmcguy was his username..
    looking good. /forums/images/graemlins/thumb.gif
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    WOW, thats a nice bracket! /forums/images/graemlins/waytogo.gif
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Oh okay. Thanks for correction me /forums/images/graemlins/waytogo.gif Looks real good /forums/images/graemlins/peace.gif
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Have you considered the pinion issues caused by running asymmetrical springs backwards? In the normal orientation, the axle is on the front of the arch and will point upward a bit as the spring droops (increasing the arch). With it reversed, the pinion will rotate downward when drooped and may result in the joint breakage due to binding.
  11. bboy
    Apr 21, 2004
    37
    that's an excellent point, it never really crossed my mind. i hope it doesn't turn the pinion down too much for it is too late to turn back now i removed the inner fenderwells last night. if i leave the rearend where it is now the fenderwells will have to be move back 3.937" to be centered over the axle at ride height. do you guys think i should cheat them back a little more for the rear axle movement during compression. i think the rearend will still clear the gas tank.
    if anyone else has ever run 56" springs backwards i would like to hear how yours reacts in droop.
    thanks, bboy
  12. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    bboy,
    I run my 56's backwards and I love them, no probs what so ever. good drop and ride. Haven't had any issues with hop off road, but I'm carefull with the clutch on road. I'm on 42s too.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep, I remember him. I remember when that rig was stock, had 32s on it, and it was his daily driver. /forums/images/graemlins/histerical.gif
  14. bboy
    Apr 21, 2004
    37
    bboy,
    thanks for the info. bboy
